New computer help please
I just put together my wife's new computer. The new system is running XP pro. Her old system runs win ME. Is there a way I can hook up the old hard drive to the new system in order to transfer files that she needs?
I believe I can set the old drive to autodetect in the CMOS and then be able to boot into win xp and then transfer the files needed one by one and the files will be changed from FAT32 to NTFS?
How to go about this?
- rockstah
Re: New computer help please
Necrovore,Necrovore wrote:I just put together my wife's new computer. The new system is running XP pro. Her old system runs win ME. Is there a way I can hook up the old hard drive to the new system in order to transfer files that she needs?
you just put the old drive inside your new computer - should recognize it as long as the old drive is configured to use any ID other than ID 0 - or in other words that you put the jumper on old drive that its set to slave.
set old drive to slave via jumper settings - hook it up in your new computer and when ya boot new machine your old drive would now be drive: D.
Mark
- Guitar Adjuster
It should work fine, the HD on my computer--drive "C" is NTFS and I have a second that is external and its FAT32, they both work fine. I have had the external for years and its worked with several different computers running XP PRO. Give it a try, the worst that could happen is your new computer will blow up
Allen
Allen
