Got a plank of wood...
Posted: Wed Aug 30, 2006 11:17 am
by Bainzy
...for making a 1959 Les Paul copy yesterday. This will be the fretboard - it's old growth Brazillian Rosewood, a perfect match for the LP.
Instead of going with a very dark brown board of it like the originals, I quickly snapped this up as I love the colour of it. Should make a gorgeous looking guitar. 8)
The bit on the left might make a nice headstock veneer - still unsure on what to do with that right now though to be honest.
Posted: Wed Aug 30, 2006 1:16 pm
by MacGaden
You
Posted: Wed Aug 30, 2006 4:15 pm
by JimiJames
Yeah ! Do the neck ! :)
Headstock... :roll:
Did a little test while back. Took a small square piece of both Standard Rosewood & Brazilian.
Like a coin took each piece and flung it flat-side down on the table as it bounced back in the air snatcing it up again...
Well... The piece of standard rosewood went "thud" and the Brazilian went "ping" ! Yeah... Uh huh !
Doing a neck is a difficult taste but has great rewards.
As previously gestured about the headstock, for me, not on a guitar aestheticly but, for a Bass 8) .
Another recommendation if there is extra BR; is to put it under your bridge pickup adjusted to your original string height so it rests solidly back in place.
If this becomes too much of a project and you decide to give up then you'll have a year supply of insense....wa...? aroma thearapy ain't a bad thing... :)
Jimmie K.
Posted: Wed Aug 30, 2006 9:15 pm
by Necrovore
Bainzy, I might suggest that when you are building the neck, if you are doing this from scratch. Do not make the neck out of a single piece of wood for two reasons.
One: Cost, Getting a workable(no knots, pits, etc.) piece of quarter-sawn Mahogany of the proper size (3"x4"x24") will be so expensive. We are talking upwards of $180-250 depending on your supplier. It is much easier to use 2-3 pieces of flat-sawn and laminate them, as one board that will allow you to pull out three portion of the neck blank will cost a fraction of the single piece. I ate two neck blanks doing it the single piece method.
Two: Stability. Using a multiple laminate neck blank increases the strength of the neck. Especially around the crucial neck/headstock joint. I prefer a three piece laminates as you can glue the center piece the opposite direction of the outer pieces. This will enable you to have a strong neck, if you plan on building a thinner neck and you wont have to use graphite runners.
Posted: Thu Aug 31, 2006 2:37 pm
by Bainzy
[quote="MacGaden"]You
