Echoplex Restoration Story
Re: Echoplex Restoration Story
ok guys … so when the fuck is someone gonna propose an echoplex kit ( pcb , tape cartridges , weird values pots etc ...) ??
the full tone tube tape echo is too damn expensive !
this ought to happen !
Electronics not the problem at all, but mechanical parts is another story.
hence the need for a company kit , i can make a parts list for boards for myself no problem ,but the mechanical parts and the case are a company matter ...Haze13 wrote:Electronics not the problem at all, but mechanical parts is another story.
- Xplorer
indeed, this would be a great idea, although it'd need a lot of funds to start such business.
or .... a forum echoplex kit, group buy .... but i think it would cost more than a used echoplex on eBay.
re building the mechanics is too complex i think.
finding enough stock of the right heads is too complicate and expensive.
same for the motor, plate, Wheel, etc ...
forget the TTE ! buy a used echoplex for cheap and restor it. it's Worth it.
i provided the traces for each board, and it's possible to find most components.
- rgorke
So, update on my "restoration". Mine was functional, but not perfect. After hearing Eric's after he got it serviced from Tony at Orbitz, I decided to improve mine. So, a couple of discoveries:
1) The bias trim on the far right board (where the record/erase head connects) is critical for perfect clean repeats. And, for complete erase.
2) I was getting a lot of floor noise with the volume pot (not record level underneath) barely past 1 or 2. So, I replaced the A500k pot and THAT made a huge difference in noise. The unit is not perfectly quiet, especially with the gain dimed on a plexi but it is drastically better.
3) I also changed the spec I had to an earlier model. I will try and find the link to what the guy I copied did. He edited the schematic. It goes back to what we talked about here about building the EP preamp pedal.
So, a couple more tips in case folks are trying to dial in their EP3. I'll try and post a clip or two. Very fun to play with...echos almost like a digital delay, but better!!!
- vanhalen5150
1969 receipt from Manny's in NYC.
Amongst other things Hendrix bought an Echoplex for $200.
- 10516744_521821767963130_7808297776948054210_n[1].jpg (152.8 KiB) Viewed 8264 times
- rgorke
And a Les Paul for $670!!!vanhalen5150 wrote:1969 receipt from Manny's in NYC.
- vanhalen5150
Yeah but I'm sure in todays dollars that total bill is pretty huge. What type of Echoplex was around in 69 though?
- rgorke
EP1 or EP2, the tube based ones??vanhalen5150 wrote:Yeah but I'm sure in todays dollars that total bill is pretty huge. What type of Echoplex was around in 69 though?
- Froumy
Has anyone used a replacement head from the link posted?
http://www.jrfmagnetics.com/index.html? ... heads.html
Any other options? (my preamp is fine, suspect heads)
Great thread. Looks like I'll have to bust out my EP3 repair project, again. Thanks!
- rgorke
You can "test" the head to see if you have continuity from the head to the me of the lead.Froumy wrote:Has anyone used a replacement head from the link posted?
And yes, that is THE guy. But don't tell anyone. I dont want him to run out in case I need another head!
- Froumy
You the man!
Can you clarify from the head to the me of the lead? (Which connection,etc). Thanks again!
- rgorke
Do you mean the color of the lead? Can't recall off the top of my head which is record or erase. They attach by the Nortronics black box.Froumy wrote:You the man!
To check to make sure your wires are not bad, stick the wires with needles right right wear the wires go into the head and re-check the continuity test..
My echoplex is making a clicking noise only when engaged, Its not a mechanical noise, it comes through the amp when the unit is engaged it, starts out slow and gradually gets faster. I have changed tapes, it must be a bad component any ideas where to look?
- rgorke
Have you cleaned and demagnetized the heads? Did this just start?
