Just got a batch of new 1969 style SuperLead chassis. These are similar to the ones that came with the MetroAmp 1969 kits, except they are made from steel (not aluminum). They also have the extra hole on the front for folks that want to incorporate the polarity switch, as well as holes on the back that can be used for an FX loop, etal.
New! 1969 Steel Chassis for Stand-up PT
Moderators: VelvetGeorge, BUG, ValveStorm
- Supporting Advertiser
Re: New! 1969 Steel Chassis for Stand-up PT
Excellent, might need one of those soon...............ValveStorm wrote:Just got a batch of new 1969 style SuperLead chassis. These are similar to the ones that came with the MetroAmp 1969 kits, except they are made from steel (not aluminum). They also have the extra hole on the front for folks that want to incorporate the polarity switch, as well as holes on the back that can be used for an FX loop, etal.
Hey all,
Looking to pull the trigger on the new '69 chassis. But, is there someone who can/does make metal panel plates for this chassis with a polarity switch and four output jacks? Here's to hoping.
Thanks,
Hale
Thanks,
Hale
Everything sounds better with volume!
We can have metal plate made for this chassis, but:
1) They are expensive... about $120 per set
2) The maximum wide of the material is 24 inches. A typical back plate is 25 inches.
