It's been a long time since my last post, so i decided to do a bit of sharing of my work.. Thanks to Tazin and his amazing work on drawing 50w and 100w chassis i have been able to draw a couple of faceplates that would perfectly fit those chassis - if you ever decide to build one yourself rather than order from a webstore. My goal is to create JTM45, JTM50 and JMP50 plexi frontplate replicas as well as JTM50 and JMP50 rear plates. So far i have done JTM50 faceplate and those rearplates. The font i've used is London Underground with a slight modification for the rear plate - letter M is different; on the front plate it has parallel M outlines, whereas on the rear plate the M outlines are angled inwards. Also i have tried to duplicate the font that says MADE IN ENGLAND... and also J.T.M...
I think that it looks pretty close to the original, but would highly appreciate if someone could compare those with the dimensions/spec/fonts of the originals so that i could make more accurate versions that anyone could use - take to a local engraver and have a really nice plexi replica plates.
I've attached PDF files of my work as well as Tazin 50w chassis pdf (i hope he doesn't mind), but if you decide you need a CDR file, please let me know here.
* i have uploaded 2 rear plates, one with bulgin socket and the other with IEC socket cutout where the opening measures 29mm x 21mm (to fit this socket http://image.made-in-china.com/2f0j00ie ... eries-.jpg" onclick="window.open(this.href);return false;)
Hope this helps someone
Regards,
Luka
