I've built myself a JMP 12xxx series replica. It's not my first amp, it comes after a Bluesbreaker, a '68 Super Bass, a JTM 45/100 and a Fender Tweed Deluxe (plus many and many mods here and there).
Heyboer transformers, Svetlana Winged C as power tubes, Alpha pots, Larry Grounding and everything you can see in the pictures, including some juicy NOS stuff.
Seems to be a clean build (hope you appreciate!), and it sounds really really well. But.
I noticed that while rolling off the guitar(s) volume for getting a cleaner sound, it scratches just like when the pot is going bad. Not the same with the tone. The more you open the volume pot, the more scratch increases. Same with all my other guitars on the amp, not the same on the other amps I've built.
And oh, on my Les Paul R8 it also gives pop while switching with the pickup selector.
It seems to be some DC leak, so I first put my attention on the NOS stuff. Tried replacing the 2n2 mustard coupling, but nothing changed. I tried re-doing almost all the soldering traces on the inputs and in the preamp section (except for the tubes sockets), but again nothing changed.
I also considered a possibile grounding issue, because the holes done for the Larry Gounding points are much wider than the screws I used for the ground lugs, but nonetheless every point that is intended to be grounded gives good continuity with the chassis when tried with the tester.
Actually I'm considering the following:
- any issue in the NOS electrolytics I (stupidly) used on the V1A cathode and in the bias section;
- any issue in one of the tone stack NOS Mustards caps, especially the right one hidden under the preamp filtering caps that at a certain point, after been soldered, has suffered a hard mechanical stress (for reasons that's hard to describe here) and appears cracked in the joining point of the yellow covering with the capacitor's lead.
- any issue in any of the other Mustard caps.
Can someone help me? Anybody who encountered the same problem?
