I see some nice Centralab pots there, which have such a tasty sound!
*EDIT* - After looking at the pics longer, maybe they are not CRL(Centralab) pots? Possibly IRC pots?
- reychapa
Some have tried the José Arredondo mod?.. is very good
- reychapa
From this mod, I have taken the first two stages of 1k / 680n and maintained the fourth stage. Also the modification of the tonestack.
It gives you a wide range of sounds depending on how you moved the knobs.
The diodes in antiparallel is not a bad idea, if you want to have the whole package in one
I have tried different Jose mods many a time and cant really warm to them, a good 36 mod sounds better to me.reychapa wrote: ↑Tue Jan 21, 2020 7:39 amFrom this mod, I have taken the first two stages of 1k / 680n and maintained the fourth stage. Also the modification of the tonestack.
The Mark V is more or less like a one wire mod. It has 2 stages + CF and the 36 has 3 stages + CF.
- reychapa
The resistive dividers that I use to divide between the first two stages are those of 68k / 68k emulating the two channels of a Cascading Super Lead
Hi guys - thanks to Duke for contacting me on LinkedIn...I'm back tinkering with amps again
Well you gotta keep at it lolpjoliver182 wrote: ↑Wed Jan 22, 2020 8:59 amHi guys - thanks to Duke for contacting me on LinkedIn...I'm back tinkering with amps again
- reychapa
demo of Jose Arredondo and Frank Levi mixed.
https://soundclick.com/r/s8bnn4
Details
- Noise Gate (ISP)
- Rebote delay 2.5, CE-2 (Input)
- Mic Condenser Kolke (Cheap, very)
- Cubase X5 (Eq) Rock Master, Compressor (Friendly), Reverd Single
Details
- Noise Gate (ISP)
- reychapa
You are running too much FX, there is more fx than guitar tone, it should be the other way round,reychapa wrote: ↑Fri Jan 24, 2020 12:07 pmBrown Sound..
https://soundclick.com/r/s8bnoz
Description in track
Can you guys give me some feedback on my amp?
Ive only recorded the distorted parts
https://www.soundclick.com/member/playl ... ID=1190423
Thanks in advance
Paul
Thanks in advance
Paul
