why would somebody prefer to remove the choke?
does it give a more hollow sound?
According to a person on the plexipalace who claimed he bought some old marshalls from ac/dc their tech had removed the chokes on the marshalls. the amps were pretty much stock otherwise (with possible exception for installed fans).
That doesn't make sense to me...the choke is in there to add inductance to the power supply, in order to filter it better.
As I understand it...the cleanest power would be a battery...the first amplified radios had batteries,probably because a lot of people didn't have Electrical service in their homes,and secondly;power supply filtering probably wasn't sufficiently advanced.
That's why the high voltage transformer output is called B+. (Battery)
I know of only 3 things that are used to filter the rectified DC : Capacitance (Electrolytic's),Resistance , and Inductance.
Tech's call these L - C - R (L = Inductance, C = Capacitance, and R = Resistance).
So the circuits to filter out the artifacts of AC from the DC are called L-C,or L-C-R.
I LOVE AC/DC (The Band)...have most everything they made on CD,and Vinyl.
If the tech took out the Choke (Inductor)...that would give you some voltage boost, but at the expense of 60 HZ or multiples of 60 HZ noise.
Maybe THAT's the Point! Maybe they wanted the noise! LOL
'76 Les Paul Custom,'68 Small Cab 50W head,'65 Blackface Twin Reverb,EV_SRO-12's,Miller PA Horn Speakers,EV Midrange Horns.Fender 400 PS bass head + one 18" 'W' bass bin.I'd like to buy a chrome stand for the PS Head.
- mightymike
I thought they replaced that choke with a resistor though. Probably to keep the volatege the same, by matching the equivelent resistance of the choke. I wouldn't be suprised if it was a 100 ohm resistor.. Unless I have them confused with someone else.
So yes the B+ would be filtered less without a choke, but that lower filtering is part of their sound.
I don't know,mike.
100 ohms seems like a lot of resistance,chokes are usually kinda heavy wire,especially in Power Supply circuits.
If the chokes were just bypassed,you'd get a bit more voltage...
But a Variac would do the same thing, and you just need to plug it in, instead of desoldering/unbolting/resoldering the supply wire and the output wire.
There may be more to this than we know
In any event, I sure hope somebody posts the "What was done,and why"...'cause I'm
- mightymike
- 908ssp
- wadeberglund
- novosibir
mightymike wrote:Would a welkin 1k 5watt be enough power rating?
5W @ 100 ohms is ok!wadeberglund wrote:Hiwatts use a 100Ohm 5W resistor here (instead of a choke), so that power rating should be just fine.
but 1K (= 1,000 ohms) would require at least a power rating of 25W, better 50W
Larry
- wadeberglund
- mightymike
Wow the Dumbles used that, holy crap Robben Ford, Hiwatts, and I bet SRV's Dumble SSS had that then too.
I bet that extra compression full tilt, would be awesome with a strat to thicken it up a little with that compression.
Oh man I have to experimentwith this.
Thanks for the heads-up on the wattage rating Larry.
Hi Mike,
I believe that most of the Trainwrecks use a power resistor instead a choke, too?
For testing, make it switchable: Choke, 100R, 470R, 1K etc.
Those nice power resistors (the ones with the gold anodized aluminum case) are optimal, IMO.
25 Watts or even better, 50 Watts, like Larry said- so you don't need a heat sink.
And then report what you prefer, please!
Regards
Robert
Regards
Robert
- novosibir
Or adjustable - with a 1K/50W rheostat:robert wrote:For testing, make it switchable: Choke, 100R, 470R, 1K etc.
http://www.larry-amplification.de/briti ... pur091.jpg
Larry
