that chord would be for instance:.a diminished chord has double flat 7 = 1 b3 b5 bb7.
1 b3 b5 bb7
B D F G
right? A, the 7th note, double flatted is G.
Bminor 7b5 - seventh chord harmony of c major is B D F A ( 1 b3 b5 b7)rgalpin wrote:that chord would be for instance:.a diminished chord has double flat 7 = 1 b3 b5 bb7.
1 b3 b5 bb7
B D F G
correct. its all about harmony of the scale so the VII chord in c major is b minor 7b5. this chord comes from the scale itself staring on b and it is spelled as b minor7b5.rgalpin wrote:so, the 7th mode has the HALF diminished. the 7th is NOT double flatted.
in contrast to the full diminished which WOULD have a bb7th.
Yep,rgalpin wrote:so, the 7th mode has the HALF diminished. the 7th is NOT double flatted.
so, does the fully diminished chord occur naturally anywhere in the scale of chords? or does it exist to help destroy the current key and lead to another?tonejones wrote:Yep,rgalpin wrote:so, the 7th mode has the HALF diminished. the 7th is NOT double flatted.
I dig the fully diminished 7th chord though, it's symmetrical...all the notes are exactly 3 frets/half steps apart:
B--D--F--Ab--then B again.
Another cool thing about this chord is that you can use any of the notes as a leading tone/maj. 7th to modulate to another key with ease.
is the harmonic minor where you flat the 7th in a descending line but leave the 7th as is in an ascending one?harmonic minor is 1 2 b3 4 5 b6 7
Actually you ascend with melodic minor and descend with natural minor.i do believe in classical music it is the strict rule or at least something to be aware of, that ascending with natural minor( aeolian) and descending with melodic minor.
The origin of this scale is easy to see when you recognize this was done so they could use a dominant 7 chord in a minor key.rockstah wrote:aeolian being a natural minor scale 1 2 b3 4 5 b6 b7
harmonic minor scale is a natural minor scale with a major 7 so:
indeed +1tonejones wrote:The origin of this scale is easy to see when you recognize this was done so they could use a dominant 7 chord in a minor key.rockstah wrote:aeolian being a natural minor scale 1 2 b3 4 5 b6 b7
Diatonically a 5 chord in A nat. minor would be e g b d: an e min 7.
Raise that g to g# a voila!!!!
