MASS 150 is on its way!
I havent tried the Line Out properly yet but I dont see it being any different from my old MASS which was great. I dont think amnything on the MASS does anything different from a typical line out. It taps a little bit of the signal strait from the output of the amp before the load. I wouldnt see how or why anyone would do it differently. With a load on the signal you would only need a small resistor and pot to acheive a line out on the raw speaker output signal despite how large it is. The only thing with the MASS 150 is you dont get a level control for it but its easy ernough to add.
With my old MASS I would just run the Line Out striat to a poweramp via effects. I would think using a speaker simulator anywhere in that chain would sound horrific. Maybe not. Im still on the fence about methods to use delay on my rig. I still have the load-lineout-poweramp method and I can still do the wet/dry method but I dont know.
Oddly enough, the amp Im having the most fun with with the 150 is the SLO. The Marshalls sound great of coarse and the SLO will never achieve the character dynamics or harmonic complexity of the old Marshalls but when dimed it has a character that was always way too bright with a HP or MASS100. I can curb the highs with the hi knob on the 150 and play with that super tight chunky rock sound. Like 800s 900s and 2000s when the gain knob is too high on the SLO it gets noisy and kind of looses it but for medium gain rock stuff its awesome. Im not much for the modern hi gain amp liek the SLO but everytime I start thinkin about possibly selling it I get a reminder of just how much of a great amp it is.
- rgalpin
I'm running my line out from the 150 into a mixer (so, I lied a little in my previous post - the point I was making was I dropped the EQ from the chain when I got the 150). I just have a little single space mixer in my rack. I have a delay unit running thru the effects loop of the mixer. It sounds great - the delay and the dry signal going through the same power amp and to the same speakers adds a nice blending of the effect with the dry that is pleasing to my ear. Separating the dry and the effect into separate cabinets creates a different feel that loses some focus. I like to hear the delay and the dry interact a little tiny bit - the dry pushing the delay out of the way a little when you really dig into something. It adds a dynamic element that is cool and subtle. And most importantly - only requires one cabinet!!!
So your using the mixer preamp in your signal chain. Something like Ritchie Blackmore using that tape echo minus the echo to make the sound warmer. Ive used worse though. Ive run a line out into the front end of bass and keyboard combos before and PA heads (the SS, built in mixer kind not the old marshalls). If, instead of using the mixer you ran the line out to a stereo delay or chorus or something you would get a stereo split without hauling out a mixer.
- rgalpin
Interesting. I never considered that the mixer was warming it up. I introduced the mixer into the chain at the same time I switched from the RedBox to the MASS. Maybe the warmth added by the mixer is what made the EQ unnecessary. ??
Prior to this setup, I was running the line out into a TC Electronics M-One XL effects unit. But I only used one side. I'm not using the mixer to get stereo. I run a mono rig. The mixer allows me more flexibility in adjusting the amount of delay on the fly than the M-One did.
Using the 150 as an attenuator, I noticed that it lets you adjust the amount of attenuation while your playing. So you can hear the adjustment in real time. The Power Break I was using before the 150 would pop the HT fuse if you adjusted the attenuation while you were playing. And the Power Break had pretty big jumps in attenuation from one giant click to the next. The 150 attenuators on the highs and the lows feel more like volume knobs - allowing you to make very fine adjustments while you listen.
Maybe its not? It depends on whther your plugging it into the channel strips preamp or not. It may be though.rgalpin wrote:Interesting. I never considered that the mixer was warming it up. I introduced the mixer into the chain at the same time I switched from the RedBox to the MASS. Maybe the warmth added by the mixer is what made the EQ unnecessary. ??
OK I got ya nowI'm not using the mixer to get stereo. I run a mono rig. The mixer allows me more flexibility in adjusting the amount of delay on the fly than the M-One did.
Its great to have the continuous control. Its like dialing in the beef then the cut. I still have yet to really get it loud, like stage volume, but Im pretty happy with it. I love the feel of wire wound pots
Ok I'm sold !!..I've been itching to replace my powerbrake..A friend of mine has the old 50 watt MASS and it's much better than the powerbrake he had. I've had pretty good luck with Weber products in the past and have no reason to think any different with this product.
BB , thanks for the informative review/updates
- GIBSON Les Paul
Ive only used it with my 2x12 8 ohm cabs so far. Just like the regular MASS it gets very hot but that seems to be normal. Ive actually used it quite a bit at stage volumes now. I still like it very much but the twin attenuator knobs at hi&lo arent as midway at higher volumes. More like the Hi is an active bright control at that point. Its still my favorite attenuator for Marshalls thus far.
- rgalpin
Well, after a 2 -1/2 half month fiasco i finally got my MASS 150 ! i will say i like it a lot though..i probably coudn't have timed my order any worse as they had JUST run out of the big chassi that they were using. They decided to start using the newer sytle chassis that the regular MASS uses. Of course this entailed a little R&D and the boxes had to be screened (which they had to try a couple of times) as well. Long story short I really like it and the two volumes seem to make it more versatile even at relatively low volumes. I do like the newer /smaller chassis as well. Like you guys mentioned the thing does get hot. In fact when i first fired it up i could smell it a bit and actually saw a bit of haze/smoke (very light). No symptoms and it stopped so i figured it was the "burn in"
. All in all highly recommended !
