MR SCARY
- plexified
Re: Lynchy Bones
This thread is gonna blow up ! Stay tuned metro friends...he he
- vanhalen5150
- vanhalen5150
Re: Lynchy Bones
Needs a dentist soon.
- image.jpg (116.56 KiB) Viewed 4924 times
- vanhalen5150
Re: Lynchy Bones
Roughing out some gangly fingers. Creepy.
- image.jpg (109 KiB) Viewed 4915 times
- image.jpg (114.55 KiB) Viewed 4915 times
- vanhalen5150
Re: Lynchy Bones
- image[2].jpg (106.31 KiB) Viewed 4857 times
- vanhalen5150
Re: Lynchy Bones
This blank came from Warmouth. It already had a large control cavity routed so I filled most of it in except for enough space for a single pot. I'll leave the original cavity plate on I think. I actually have a German made Floyd. I just have to fiqure out how I'm going to get a wire over to the jack. I didn't think about that when I filled it in.
I think I'll shoot some black over it first and then hand brush some acrylic white and black. I also have some semi gloss nitro.
I found an ESP backplate that is for a contoured heel. Its looks crocked in the pic but it just has some weird angles.
- image[3].jpg (98.71 KiB) Viewed 4857 times
- image[1].jpg (84.56 KiB) Viewed 4857 times
- plexified
Re: Lynchy Bones
Mr. Scary is definitely a worthy heading , sorry you changed it . The build looks awesome . Did you consider my suggestion for the rear control cavity and the paint ? HIt me back and if you want a period correct Floyd , I have one . The origionals had fucked up heights on the saddles and could not match neck radius profiles . AND think of a one meg volume pot for this beast ! if you do not like it full up , we used to file off the "difference" or the off spot . So it became an on off switch so to speak .
- plexified
Re: MR SCARY
Ahh , well everyone used to think the Fender guitars of old sounded so good because of the nitro paint being thin and such . Well it turns out it was actually the sealer that was rock solid . Kramer and EVH used a hard resin on the bodies that was super close and was a key to the tone . Its a resin that can be buffed with a compound and a wheel and resists heat . You can put out cigarettes on it . But its got the mojo . Usually you can pick it up at an auto body supply . I like the acrylic resin cause its easier to clean up after , but its all good . It will fill in the woodgrain and I have dipped a lot of bodies . I do a special swirl paint job too . The resin sealer is critical , because I use water to suspend the paint when I do a swirl . The paint is oil based and floats so its super cool to see what shows up on the body when done . Like the Vai DNA gtr . I don't use blood , but still way cool Jr. I also use the resin straight so the dry time is super long . This way you can brush it on and just wait instead of a spray set up . Cleaning this stuff from your gun is a drag .
- vanhalen5150
Re: MR SCARY
SRV's strat does not look like it had been painted (sealed etc) with anything "rock solid"
- vanhalen5150
Re: MR SCARY
I remember trying to remove some type of stuff under the paint of a Pacer body. I tried stripper but nothing worked. I busted out the heat gun and roasted the wood underneath.
- vanhalen5150
- NY Chief
- Wiki Editor
Re: MR SCARY
Fender started using that Fullerplast around '61 I understand.
