'69 SuperPlexi Metrobuild
syscokid
Re: '69 SuperPlexi Metrobuild
Post by syscokid » Sun Aug 07, 2011 4:38 pm
S.Marshall wrote:Looks like he switched positions of the Presence and PPIMV.
Thanks...
I should have looked carefully at the other pics... :oops:
JimiJames
Steps 15 & 16
Post by JimiJames » Tue Aug 09, 2011 11:57 pm
Well, that knob was supposed to remotely control the thermastat to the fridge but, I was having problems installing the firmware. The manual said to upgrade the software berfore I do that... It was getting to be to much PITA anyway so I just picked up a newer model that had BlueTooth technology cuz ya' know I like my beers cold ! Aye don't be surprised ? I've got it Wifi 'd to the chip on the label to that makes the letters turn blue so I know they're ice cold :P
uhh y e a h... and the colder the beer the more I drink and things happen. ehh I start to see colors...
______________________________________________________________________________________________
I tac welded everything on the board deciding on what I want to start off with until more parts (resistors) come in the mail.
More change ups for sure... I'll get it so where atleast I can fire it up and get readings/voltages where they belong.
Then.... more changes... and even more changes and possibly then make my Loop & MV connections...
gettin' closer...
Image Image Image Image Image Image Image Image ImageImage Image Image Image Image Image Image Image ImageImage Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image
Reason: Updating
Build'sClip'sVid's
syscokid
Post by syscokid » Wed Aug 10, 2011 1:48 pm
That resistor is huge... :shock:
What kind, or brand of cap is that?
JimiJames
Post by JimiJames » Wed Aug 10, 2011 6:14 pm
The resistor is a 2W Ohmite 2.7k +/- 10% registering .294 or 2.9. It's the right value and the only 2.7K CC I have on hand and should work for now.
As for the cap; it's an ITW .68 200v (in Fenders, IDK?). I have the Mustard's but, have these on hand as well that I wanted to try instead of the Mustard's that are rated @ 160v. I'll see when I get there...T h e n the tweaking madness begins...
Build'sClip'sVid's
JimiJames
Blowing fuses ?
Post by JimiJames » Fri Aug 19, 2011 2:57 am
Aye guys, hit a little snag. Blowing fuses.
Need an extra pair of eyes or two. I don't see anything with my limited knowledge and was hoping the experts can sniper the culprit.
I caught one bonehead move with the lamp. I installed it as per instructions but, forgot I was using a 6v. Everything else looks good to me. I documented all of the parts/values so I thought I had things covered there. I don't think there's a problem with the OHMITE 2watt 2.7k. Other than that, IDK ? So there is no lamp, temporarily.
I checked under the board referencing pic's and that also looked good.
I fully soldered the connections (no tac weld)
I put in 1A SB fuse flipped the Mains Power switch on and it stayed on (I could hear the PT) and was able to get a reading off the heaters. @ 3.41v. Preamp tubes lit up nicely. Those are the only pins that read on all tubes. Got the bias reading too @ -35 trim pot up all the way. That's it. I cannot get any other readings... :what: Fuse eventually blew turning on the stand-by.
The Loop & MV are mounted they're not connected. I have temp wires that will be removed for install.
Dual voltage switch wiring perhaps?
Please let me know what info is needed to troubleshoot & I will supply.
Thanks ! :thumbsup:
(Temp wires in place to get readings. pre Loop & MV connections)
Image Image
Build'sClip'sVid's
JimiJames
Post by JimiJames » Fri Aug 19, 2011 10:48 pm
Found a pin missing off one of the preamp tubes. After taking a hammer to it, I replaced it and stopped blowing fuses.
Now, with the Power switch on I still can only get just the heaters to register (with or without pre's installed)
I hear the PT humming. Not sure on the OT ?
Build'sClip'sVid's
JimiJames
Post by JimiJames » Sun Aug 21, 2011 5:28 pm
What are the chances of 2 tubes with the same coincidence ? :stars:
That's why I have a room at Bellevue, kids. Tucked away in a dark corner of the building... :bang: :lol:
Build'sClip'sVid's
syscokid
Post by syscokid » Sun Aug 21, 2011 8:24 pm
...obviously, the Pin Fairy is back... :twisted:
JimiJames
Post by JimiJames » Sun Aug 28, 2011 3:05 pm
yeah... here's her sidekick... PowerTube the clown looks like he lost one of his teeth...
I new there was more to this show... :bang: :palm:
Build'sClip'sVid's
JimiJames
PPIMV & ZeroLoss effect loop
Post by JimiJames » Sun Aug 28, 2011 3:12 pm
Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image Image ImageImage Image Image Image Image Image Image Image Image Image
Reason: Updating
Build'sClip'sVid's
FourT6and2
Post by FourT6and2 » Sun Sep 04, 2011 4:49 pm
Very nice! Not to toot my own horn, but it looks cleaner than my build. Great job. :)
http://fc07.deviantart.net/fs71/f/2010/ ... 32srow.jpg" onclick="window.open(this.href);return false;
