Amp Check and Bias
metalhead3ecr
Re: Amp Check and Bias
Post by metalhead3ecr » Thu Nov 22, 2012 10:00 am
Is this looking any better?
I ran out of solder for the moment...but the connections will be a lot more solid and shiny when I get some more. Also, is it normal to use the two Mallory 150's there? Should I swap them out?
(419.13 KiB) Downloaded 600 times
julkke
Post by julkke » Thu Nov 22, 2012 10:14 am
The joints could be better. When soldering, you gotta heat up the component's leg and the turret, and feed the solder to those, not to the soldering irons tip.
I suggest to watch this video, it's really kewl http://www.youtube.com/watch?v=cIDydYIVTqU" onclick="window.open(this.href);return false;
The mallories will be fine.
metalhead3ecr
Post by metalhead3ecr » Fri Nov 23, 2012 11:16 pm
I am getting 0 on pins 1 and 8 of the power tubes. Everything else is up to snuff (o.k. readings, fuses are good, DMM is good)...where should I troubleshoot?
I know Curt's amp has some different resistors in this area. Should I change the 47k , 150k, and 15k to what Curt has?
julkke
Post by julkke » Sat Nov 24, 2012 4:19 am
Pics? Check those grounds with a multimeter. Are you using 1 ohm biasing resistors?
Post by neikeel » Sat Nov 24, 2012 5:44 am
metalhead3ecr wrote:I am getting 0 on pins 1 and 8 of the power tubes. Everything else is up to snuff (o.k. readings, fuses are good, DMM is good)...where should I troubleshoot?
But 1 and 8 of the power tubes are tied and grounded - you are not expecting any volage there (unless as already suggested you arre using the 1 ohm resistors). Remember you are measuring mV across a 1 ohm 1% resistor.
Have you checked pin 5 of your output tubes - you should have approx -40vdc there?
metalhead3ecr
Post by metalhead3ecr » Sat Nov 24, 2012 8:01 am
Yes I have the resistor to ground on V4 and V5 but I still get 0. I do have a negative bias on pin 5 after the 5.6k resistors of around -40. The power tubes look rather cold when the standby is flipped...
demonufo
Post by demonufo » Sat Nov 24, 2012 8:07 am
What meter do you have and what scale are you using?
So I like purple, okay!!!!!!
metalhead3ecr
Post by metalhead3ecr » Sat Nov 24, 2012 8:17 am
The meter is a Cen-Tech P37772 haha it's not a Fluke. And I'm on mVDC.
metalhead3ecr
Post by metalhead3ecr » Sat Nov 24, 2012 8:24 am
Here is a pic of the dmm
julkke
Post by julkke » Sat Nov 24, 2012 9:08 am
Post a pic of your power tube socket wiring.
metalhead3ecr
Post by metalhead3ecr » Sat Nov 24, 2012 12:03 pm
Hope these help. I plan on cleaning all the sockets up today. Kinda tough to see with the Xicon's in the way...
(334.52 KiB) Downloaded 534 times
(422.65 KiB) Downloaded 534 times
(360.5 KiB) Downloaded 534 times
julkke
Post by julkke » Sat Nov 24, 2012 12:22 pm
Yeah a bit hard to see. Have you checked with your meter that pins 1 and 8 are getting ground connection?
metalhead3ecr
Post by metalhead3ecr » Sat Nov 24, 2012 12:28 pm
Yup. I got the beep of continuity. I did notice I was missing two grounding wires on the 1st stage. I just added them. Maybe this will fix it?
julkke
Post by julkke » Sat Nov 24, 2012 12:31 pm
Try it and see. Check everything against a layout again.
metalhead3ecr
Post by metalhead3ecr » Sat Nov 24, 2012 1:30 pm
I think that is the ticket! Thanks for all your help. However I need some new preamp tube sockets.Mine are so mangled it's dangerous... Are there ones that can handle my sloppy soldering :oops: Any recommendations?
