Everything We Know So Far
Ralle
Re: Everything We Know So Far
Post by Ralle » Wed Aug 08, 2018 5:54 pm
" The audio clips sound so good...I've got to try this setup. The only thing I can't quite understand is the line out even though you've explained it a couple of times already. What is the impedance of the line out (reference to ground) with the 0.68 ohm setup? The line out I currently have is similar to the one used on the Hotplate attenuator which uses a 5K pot along with two resistors (a 1K and a 470 ohm I believe). "
That works fine as well, but that is the line out I described as the " more common here on the forum ", wich isn't bad in any way... works like charm. The difference lays in the " 0.68 ohm line out; Since that's all I have over the cab/mixer/powerstage or what ever you want to drive, I loose less signal comparerd to having the other setup ( 1-5k/470ohm ) simply cause there's less resistance... Both ways works very well, the one with the less resistance have less lost of signal/freqs or what ever it is... There is an audioable difference, I've tried both.
The impediance ( with the cab ) to ground must be the cabs impediance thrue the lineout; 1x8+1x0.68 and since I happen to have a calculator laying around the result would be... hang on... 0.63ohms... take that in serie with the big on and you get 0.63+8= 8.63 ohm total from the main amp. If I'm using the reamping you do the same calculation with the small resistor and the resistance in th input of either the mixer or the PA head input... and both are well over several k's... you will NEVER go over 0.68 ohms no matter what you do, as long as you hook up the small resistor across the input of what ever your using.
This variant is very easy to build, suppose you have a big load for the mainamp, just hook up a simular resistor ( preferably an effect resistor ) of a small value in serie towoards ground, and hook up your other inputs ( amp, mixer or what ever)... I have an effect resistor of 0.68 ohm ( well actually I have four, two in serie and thos two in parralell, but I still get the same value, I just wanted to be on the safe side powerwise )... :wink:
Ralle
Post by Ralle » Wed Aug 08, 2018 5:56 pm
jnew wrote:
Wed Aug 08, 2018 5:08 pm
I think what he is saying is, if after the load resistor you add another .68 resistor, that would be your line out signal to the Master PA amp. It sounds like a fixed line out as opposed to the 5K pot, 470 Ohm and 1K resistor that you talk about. That is variable with the pot sweep and all. I think his is just fixed with a .68 only. :what:
That is a much better describtion of what I ment... thanx... :wink:
Ralle
Post by Ralle » Wed Aug 08, 2018 6:01 pm
" That would also yield a fairly high voltage output since a 0.68 ohm isn't going to drop much voltage "
There I'm lost... what do you mean by that?
All I know is that the lower the resistance/impeadiance, the lower the volume... in this possition, that is :oops:
Tazin
Post by Tazin » Wed Aug 08, 2018 7:59 pm
Ok, I got it now...Thanks for clarifying.
Ralle
Post by Ralle » Wed Aug 08, 2018 9:30 pm
No problems... :wink:
DeanUlve
Post by DeanUlve » Sat Aug 11, 2018 1:23 pm
Is there a Line Out box available that meets the specs you've laid out, for those of us that are not builder savvy?
:scratch:
Ralle
Post by Ralle » Sat Aug 11, 2018 5:16 pm
I actually don't know... I guess others in this forum can awnser that better than me :oops:
Tazin
Post by Tazin » Tue Aug 14, 2018 4:01 pm
I had an hour or so of free time so I decided to try a setup kinda similar to Ralle's but using a straight forward Super Lead and a late 70 "Lead" 50w. The overall results weren't too bad although I didn't try any pedals with the setup. Here's what I used:
MAIN AMP: Straight forward '68 100w Super Lead specs with split-cathode arrangement (no oddball parts). Amp setting were similar to Ralle's but with the Treble cut back a little. Guitar plugged into the Bright channel "High" input.
SECOND AMP: A 50w late 1970 "Lead" specs with split-cathode arrangement. Once again the amp setting were similar to Ralle's except the Treble was backed off a little. The Line out from the load box was plugged into the Normal channel's "Low" sensitivity input jack.
LOAD BOX: An Ohmite 25 ohm 225 watt adjustable resistor set to 20 ohms with a Friedman style line out. The Friedman style line out uses a 1K5 resistor along with a 10K Audio pot and a 470 ohm resistor.
So, like I said overall it didn't sound too bad but you can tell the frequencies need a bit of shifting to possibly make it sound better. Therefore, revamping my 50w amp to either a "Bass" spec or "PA" spec may help dial in the frequencies a tad better.
jnew
Post by jnew » Tue Aug 14, 2018 5:39 pm
That’s the idea and yes, Ralle is using Plaap specs on his main head, which are specs more aligned with a bass circuit, as is circuit used to re-amp. No treble caps and bypass caps, etc.
I just scored a 69 Super Tremolo so I will use that modded to Master PA specs. :rock:
plexified
Post by plexified » Wed Aug 15, 2018 3:50 am
I'm amazed that this is still going on. Thank God we all are still at it. Here is a few good Vids to demo specific EVH things that are quite remarkable.
First is the JBLs/Greenbacks :
https://www.youtube.com/watch?v=uGSw7jB_0Kg
Second is a demo of effect simplicity and bonus LIttle Guitar Tone @ 4:00 !!
https://www.youtube.com/watch?v=gC9B6kOajEI
I'm going to add to the party with my vote for the Small Power Transformer and The Duncan Custom Custom. I add that because the Power Trans adds a very specific voltage drop that adds sag while keeping the punch for that silky bottom end and the Duncan, because it really tickles the mids and the latest EVH Eruption kind of further confirms the spec at 14.4k. If you don't want that pickup, a PAF with the 'frown' curve eq will still work if you raise the input slightly, or not. The gain structure of the Marshalls can vary a lot, so you don't want mush. You need an axe with lively sustain and enough volume to get that body resonating a bit. Last thing is pure nickel wrap strings. I find it goes with that silky bottom effect. Of course subtle stuff , but it stacks up.
In reference to the clips , they sound great!! You guys remind me of Ken Fischer when he would tweak and mess around. Your already exceeding the original tones and just adding to the pallete. Ken set up a lot of re amp rigs. They always sounded good and were easy to play with more solutions to venues, exactly what your describing. Whats funny is its all in the 'range' of the formula. More than one right combination for a rig that evolved. Komet is building this amp now with the re amp w/d/w the ambicab, might give you some ideas Jnew, http://www.harmonycentral.com/articles/ ... tory-visit
Peace!!! :vh:
Tazin
Post by Tazin » Wed Aug 15, 2018 2:56 pm
I had a quick chance to try a couple of pedals (vintage MXR script logo Phase 90 & vintage MXR Flanger) in the front end of the main amp today. The Phase 90 didn't sound all too good in that when engaged there is a decent volume boost and the tone has too much mids (1Khz)...Kinda has that walkie-talkie type tone. So, it's not as plush sounding compared to using it with a normal amp setup. The Flanger seemed to work better than the Phase 90 but I was encountering some stray high frequency oscillations random in nature. Also, the clock timing (or sweep timing if you will) seems a little different acting compare to normal use. Again, this was just a quick twenty-minute test. Also, I didn't put my Echoplex EP-3 in the signal chain so that my change things a little.
Tazin
Post by Tazin » Wed Aug 22, 2018 3:21 pm
Ralle, how strong is the signal coming out of your line out? Is it lower, equal, or higher in volume compared to plugging the guitar straight into your PA amp? I've got mine set so that it's the same volume whether I plug a guitar straight into my second amp or I run the line out from the load box.
Ralle
Post by Ralle » Fri Aug 24, 2018 5:32 pm
If I remember correctly, I think it's fairly equal to the pure guitar into a mixer, I checked the level and made sure it was the same into the pa head... The value/level of the lineout I have is taken from a fender amp ( can't remember wich model ) with a line out built in stock, and that was a 0.68 ohm... so I assume that should be sufficiant...
Werther or not there was any kind of volume pot involved, I don't know, but I wouldn't be suprised... Since a value of 1 ohm is good, and there are effect pots in those values, that would allso de a good choise. In fact that would be eaven better; you can adjust the level into the pa in a very posstive manner. Some of the distortion has to come from the input stage of the pa... I can switch between 0.68 and 1 ohm, and I tend to use the 1 ohm opption more, actually.
Mats A
Post by Mats A » Wed May 01, 2019 5:25 am
Tazin wrote:
Mon Jul 16, 2018 5:27 pm
Ralle wrote:
Mon Jul 16, 2018 4:53 pm
Yes... with out a doubt... there's no way he could have gotten that sound without the seccond amp... and the beauty of it is that master PA head; with the tonecontroll and pre eq master, plus the level of signal hitting the first stage in the PA head that brings the gain level up to where you never can without it. I mean, look at the PA; it has NO brightcaps anywhere, it has only one 68k input resistor, so when pushing that first stage with the signal from the first amp, you get that stage to distort in a way that makes the sound nice, thick and with the right amount of edge ( no bright caps )... The rest of the sound, well, since the powerstage of the PA head is like any other marshall head... I mean where can you go wrong... it's the ideal way to do it. You have the mastervol to controll the over all volume ( pushing the powerstage just about right ). you have the eq AFTER the mastervol; the best way to controll the freqs comming out of your cab... As you probably understand; I rest my case! :wink:
I hear what your saying and I've heard some rather convincing slaved setups capturing the "vibe" the Ed got back in the day...But how does one explain Kevin Estrada's photos of Ed playing at the Whiskey in late '77 using what appears to be only one amp?
Can you really be sure of this? I believe there is more than one way to get the tone on VHI. I’ve heard many clips using different gear that gets a very similar tone. I admit Eddie’s tone on VHI sounds different to VHII wich sounds more like a Regular Marshall into a cab. Could it be different recording and mixing that makes the difference? According to Friedman Rudy Lieren has said it was Eddie’s guitar-Flanger-Phaser-Echoplex-amp into one cab. Variac at 91V. No MXR 6 band eq. Also i’ve tried that mid boost curve Eddie has on his MXR 6 band eq on the photo and it sounds nothing like VHI. In fact it sounds nothing like Eddie at all. To me his tone doesn’t sound mid boosted on VHI. I’ve red it was only used for rental gear bad sounding guitars and amps. Or for the Univox echo wich had a low impedance input so he lost tone with it. Maybe if he did use a slaved rig the eq sounded different with this setting. Doesn’t the slaved rig sound a bit complicated for a band playing like small clubs and places.
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 4:03 pm
Nike Air Max 720
Jordans 2021
Nike Black Friday Deals 2019
New Nike Shoes
Air Force 1s
Soccer Jerseys
Nike Jordans
Jordan 31
Nike Wholesale
Nike Shox
Jordan 16
Nike Outlet Online
Cheap Nike Shoes
Jordan 13
Adidas Outlet
Retro 12
Air Jordan Shoes
Nike Metcon
Wholesale Jordans
Adidas NMD R1
Nike Shoes Canada
Nike Sneakers
Adidas Shoes For Men
Air Jordan 4
Jordan 11
Cheap Jordans
Nike Clearance
Adidas Shoes
Wholesale Jerseys China
Jordan Retros
Air Jordan 11 Retro
Air Jordan 21
Pandora Charms
NFL Shop
Jordan 27
Air Jordan 22
Michael Jordan Shoes
Pandora Jewelry
Nike Hyperdunk
Nike Hyperdunk
Nike Air Max 270
Jordan 12
What The Jordan 5s
Jordan 12
Nike Outlet
Cheap Nikes
Dior Jordan
Nike Outlet Online
Air Max
Air Jordan 13
Nike Air Force 1
Adidas Yeezy Boost 350
Air Jordan 1 Retro
Nike Running Shoes
Pandora Rings
Fjallraven Kanken
Cheap Jordans
Jordan Concord
Nikes
Nike
Roshe
Jordan 17
Jordan 29
Nike Air Force 1 High
Nike Outlet
Nike SB Dunk
Jordan 2s
Adidas Yeezy Boost 350 V2
Pandora Jewelry Official Site
Toddler Jordans
Huaraches
Adidas Outlet Online
Nike Outlet Online
Jordan AJ 1
Nike Outlet Store
Jordan 18
Nike Shoes For Women
Nike Air Zoom
Kids Jordans
Nike 270
Christian Louboutin Shoes
Wholesale Adidas
Nike Women's
Cheap Adidas
Wholesale Adidas Shoes
Jordan 25
Nike Factory Outlet Store Online
Air Jordan
Jordans 19
Nike Free
NHL Shop Canada
Epic React
Men Nike Shoes
Air Force 1 Men
Jordans 24
Air Max 95
Air Jordan 33
Nike Jordan 1 Mid
Nike Huarache Women
Nike Slippers
Nike Wholesale
Nike Outlet Store
Nike Sneakers
Jordan 28
Jordan 14
Cheap Jordan 12
Air Jordan 11 Low
Air Force Ones
Air Jordan 30
Air Jordan 34
Air Jordan 33
Nike Shoes
Louboutin
Hockey Jerseys
Pandora Bracelet
Wholesale Nike Shoes
Louboutin Shoes
Jordans 33
Nikes Shoes
Nike Wholesale Dealer
Cheap Jordans
Nike Shoes Wholesale
Jordan Shoes From China
Lebron Shoes
Nike Lunarlon
Jordans 20
Wholesale Jordans
Jordan 32
Jordan 35
Pandora Jewelry
Nike Roshe
Nikes Wholesale
Jordan 23
Nike Factory Store
Pandora Ring
MLB Shop
Adidas Yeezy 700
Nike Running Shoes For Men
Cheap NBA Jerseys
Pandora Canada
Nike Air Max 720
Pandora Jewelry
Air Force 1
Nike Air Max 2019
Nike Zoom
Huaraches
Jordans 6
NBA Store
Jordan 15
Jordan 26
Cheap Nike Shoes
Cheap Wholesale Nike Shoes Free Shipping
Off White Nike
