Here's a neat video I found at mojotone for replacing the guts in a 335 type guitar. They leave some stuff out I'd say, but it gives you some ideas. Scary watching him use that step bit, but then I've used a rat tail file more than once.
http://www.mojomusicalsupply.com/video-335.asp
335 electronics install tutorial
- NY Chief
- Wiki Editor
I just insalled that kit in an Epi Sheraton. The full size pots do NOT fir through the f holes and you have to enlarge the opening through the bridge pickup cutout to get them to fit. The other thing that they do not mention is to tie the string around the pots before you pull the old ones out. Then you can use the strings to pull the new ones in.
Their prewired assy works great. To me definitely worth the $$.
