Filter ground buss question
gtomax
Post by gtomax » Wed Dec 19, 2007 2:01 pm
Well I've got the entire power and output section wired now. I was trying to figure out what to do with the filter cap ground. Here is the grounding so far:
HT through fuse to ground lug. Same ground lug has filament ground. That's where I connected the mains/screen/PI ground buss to.
Should that have its own ground lug instead (and if so, where?) or is that alright?
gtomax
Post by gtomax » Wed Dec 19, 2007 7:47 pm
Found an answer on Aiken amp grounding FAQ that this is in fact an OK grounding scheme for the power side.
I will however re-route the B+ wires away from the main power wiring harness as I'd like to seperate AC and DC as much as possible.
