Restringing a nylon?
TomGibbs
Post by TomGibbs » Wed Jul 30, 2008 5:54 pm
hey guys, i was wondering if it would be ok to restring my nylon string acoustic with steel strings?
I would be using 9-42 guage, the reason i ask is, although theres no truss rod, i cant see 9s givin THAT much more tension than what its holding now.
Also, with guitars like Martin 0-18's which are steel strung, with no truss rod, i was wondering if it would be possible.
Thought id check with you guys first
Tom
Image Image
Yngve
Post by Yngve » Wed Jul 30, 2008 6:59 pm
Not such a good idea, especially when the tension will be much more plus the steel string will cut into the bridge. I wouldn't do it.
You should always B sharp, never B flat, and just B natural.
Success is the ability to go from one failure to another with no loss of enthusiasm - Mykola Skarpheddinson
Post by yngwie308 » Wed Jul 30, 2008 11:20 pm
Without adequate top bracing and support even with silk and steel strings, you'll be popping the top and bridge off your guitar...
TomGibbs
Post by TomGibbs » Thu Jul 31, 2008 6:01 am
Ah ok, thanks guys :)
Image Image
45auto
Post by 45auto » Thu Jul 31, 2008 10:28 am
they dont usually have truss rods do they? who's rig is that Y308? looks good!
Post by yngwie308 » Thu Jul 31, 2008 2:05 pm
Tom Keifer of Cinderella, yes he has the bases covered with that setup. Tom has always had cool guitars and amps.
Nylon stung guitars never have had truss rods.
Yngve
Post by Yngve » Thu Jul 31, 2008 7:08 pm
My Classical guitar hasa truss rod. La Patrie from Qubec Canada, l know its weird but it has.
This is my pride and joy my top guitar. David Argent what a gentle giant, even came to my home from interstate to show me his guitar, and l ended up buying the Spruce model. :D :D :D :D
Post by yngwie308 » Thu Jul 31, 2008 9:10 pm
Not cheap my friend!
This is what I have my eye on next.............
SWR California Blonde II amp, Roland GA-20 Synth, Godin Multiac SA guitar, 25.5" scale length, 16" radius, ebony fretboard, on board synth controls and equaliser. :D
