keystone turrets
keystone turrets
i have a question for you guys ..There are two keystone products (double turrets) that i wan't to identify , which one between those two products fit exacly in the same hole size as george's split turrets 1509 or 1582 ?
http://www.tube-town.net/ttstore/produc ... -Pack.html" onclick="window.open(this.href);return false;
Re: keystone turrets
Anyone ? I have a 71 superlead spec board to drill ...i really need this info , i have only one drill bit at the proper size ( split turret size ) for my dremel .....i think originals had eyelets but i plan to stack somethig more "rock solid" in it .......
- S.Marshall
I think the hole size for the split turrets from George fall in between these two Ben.
-Steve
ok i had nothing to do this afternoon so i drilled my board using the hole dimentions for george's split turrets .....
look at it ;
i didn't staked the turrets for the moment just placed them to see if all was good .... need you opinion on this guys , i keep the plit turrets or wait a little more and get eyelets or keystones ? ?
look at it ;
- S.Marshall
I really like the splits. I may even try larger ones I found but I'll stay with split turrets.
-Steve
I much prefer the metro split turrets, they are ever so slightly skinnier than a couple of bags of NOS RS components ones I picked up.
Why don't you use the metro split turrets?
problem solved ...i ended finally by stacking split turrets in this board , but if i didn't wanted to use them it is because they are very fragile when you stack them with a hammer and keystone tools , each bord i break 8 to 10 of them
- S.Marshall
Ouch Ben. Maybe you need a smaller hammer.frenchie wrote:problem solved ...i ended finally by stacking split turrets in this board , but if i didn't wanted to use them it is because they are very fragile when you stack them with a hammer and keystone tools , each bord i break 8 to 10 of them
-Steve
- Bluesgeetar
You talking about these? I cleaned the guy out. They really are cool!neikeel wrote:I much prefer the metro split turrets, they are ever so slightly skinnier than a couple of bags of NOS RS components ones I picked up.
- turrettagsx100.jpg (116.96 KiB) Viewed 3771 times
So, what's the difference between the different turrets?
