Hello
I bought some red swirl metro board material and it came with some oil on it.
http://metroamp.com/store/product_info. ... cts_id=224" onclick="window.open(this.href);return false;
How should I clean those oily boards without to damage them?
(98%alcohol, acetone (very strong), or just with water and soup?)
Thank you
Red swirl metro board material
- BLOOZE
- Structo
Re: Red swirl metro board material
Alcohol would probably be safe.
Something I use a lot for degreasing in guitar work is called naphtha, it is the same thing as Ronsonol lighter fluid.
Tom
Don't let that smoke out!
Water and soup...Campbells Tomatoe Soup works best.BLOOZE wrote:Hello
Thank you
- flemingmras
Anything that's safe on fiberglass. All that material is is several layers of fiberglass mat in polyester resin.
