Ugg, New Gold Lions, JTM45 with a VVR
yodermr
Post by yodermr » Sat Oct 24, 2009 1:24 pm
Hey guys
So I built a Metro JTM45 a few years ago. Worked great, no problem. Loud as hell, year later, I installed a VVR (Dana) between the first cap and the choke and between the Bias trim and the 220K resistors. Worked great, no problem. Zoom forward about a year...
Loud hum, then back to normal. Switched it off. Back on and watched the tubes, spark shower storm inside one tube. Shut her down. K, Figured it was time for new tubes...
Got a pair of Gold Lions, installed. Going from suggestions on this board, tried to bias at .033 but I didn't have the needed range to go that low (got down to .039). So I change the bias resistor.
Biased her in at .034mV. Sounded great. Here is where it got weird on me.
So I'm playing along with the bias meter on, letting it get warmed up to readjust the bias. Turned down the VVR and it didn't drop the volume like it used to. Umm, strange...then playing along, Red Plate (on both tubes). Looked at the bias reading, it was .157. Shut it down (I didn't recheck the plate voltage & bias voltage when it was down...assumed, as designed, they track together).
So now, I turn it on with the VVR all the way up, bias in at .034, sounds great but after a few minutes I get this toxic smell happening (thought maybe something on the new tubes, but the smell get strong) and I hear a high pitched buzz in the amp (not from the speakers). Not even going near turning the VVR down at this point
Check all voltages, seem in range. My novice brain is tapped
Help?
Thx
Mark
MBD115
Re: Ugg, New Gold Lions, JTM45 with a VVR
Post by MBD115 » Sun Oct 25, 2009 6:14 pm
I don't know but my guess would be to remove the VVR and wire the amp back right and test it then. I have no idea on how to test the amp with that device in the circuit.
Good luck.
Structo
Post by Structo » Sun Oct 25, 2009 8:32 pm
I'll bet you fried the MOSFET in the VVR.
Even though it is stated that it can handle 50 watts, it seems to me the people having problems with them are the ones with 45-50 watt amps.
And of course once distortion kicks in you are probably well over the wattage an amp is rated at.
Tom
Don't let that smoke out!
yodermr
Post by yodermr » Sun Oct 25, 2009 9:35 pm
Yup one of the mosfets was toast. With that, I guess the VVR knob becomes just a raw bias control. Like a light bulb dimmer :lol: The maker of the VVR board (Dana) to the fact that I didn't have a heat sink on it as why it probably blew to begin with.
Swap it out, add the heat sink and we'll see what we get.
Thx
m
yodermr
Post by yodermr » Sat Nov 07, 2009 2:43 pm
Hey just letting everyone know...got it all up and running. Replaced the Mosfet, added a nice heat sink on it, biased it up and away we go.
On the Gold lions...very nice. Certainly an improvement over the Valve Arts. I won't throw out a bunch of meaningless marketing descriptors, just saying, I'd definately pick GL over the VA
All said and done, my JTM45 (Sozo, Mercury Magnetics, Weber Blue Dog, etc...all the goodies) sounds/feels a better than my Fuchs, Bogner and my equally pimped out home brew TrainWreck.
Thanks for all the help
M
Post by Roe » Sun Nov 08, 2009 12:40 pm
My 45/100 just blew a gold lion after 150 hours or so
yodermr
Collateral Damage? - Ugg, New Gold Lions, JTM45 with a VVR
Post by yodermr » Sun Nov 08, 2009 1:17 pm
So, guess I need some additional guidance....The amp is up and running, playing and sounding great. Played it for a few hours over the last few days...One thing I notice though and have no idea what to do with it is that the smell is still there. Not as bad as before.
So I searched around (transformer, caps, resistors) but it seems for my expertise level I'm poking around in the dark.
Any thoughts on if this is an actual problem?, will it become one?, what I can to to diagnosis it?
Thx, much appreciated
Mark
Structo
Post by Structo » Sun Nov 08, 2009 1:44 pm
Not sure about the smell but be sure to feel the PT and OT after you have been playing for a while.
They shouldn't be so warm that you can't leave your hand on them for a minute.
If they are too hot to touch then you have a problem with the amount of current the amp is drawing.
In that event I would double check your bias setting.
New amps will have a bit of a smell when they are new but I wouldn't classify it as a burning smell.
Just the smell of new components getting warm.
Tom
yodermr
Post by yodermr » Mon Nov 09, 2009 2:52 pm
Well let it run and run, played for a few hours and the OT PT never really get past warm.
Tough smell to describe, its more metallic, chemical not really a burning smell.
Started only after the inital Mosfet failure, I've had the amp running many many hours prior to this so don't think its a new component smell.
The smell was very strong when the mosfet failed and my VVR control acted like a bias control, red plating fun. Now its much less but there.
Could I have pushed something to "sweat" bad stuff out but not actually fail? When it heats up is "burning" off whatever?
In the end it plays great....just worried about something else (the smelly part?) failing later and taking down a few more dominos :shock:
M
Structo
Post by Structo » Tue Nov 10, 2009 11:45 am
How do the resistors on the VVR board look?
Any of them discolored from heat?
It may just be one of those things where you have to wait until something goes belly up to figure out what's wrong.
Did you feel the PT to see how warm that is getting?
Remember the louder you play the more demand that is being put on the components.
Tom
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 6:26 pm
Adidas Official Site
Air Jordan 1 Dior
Nike Store
Wholesale Jordan
Adidas Sneakers
Asics
Womens Basketball Shoes
Pandora Charms
Pandora
Balenciaga Shoes
Jordan Wholesale Distributors
Balenciaga Sneakers
Adidas Shoes
Women Nike Sneakers
Adidas Running Shoes Women
Pandora
Pandora Jewelry Charms
Pandora Jewelry
Goyard Bags Outlet
Cheap Adidas
Pandora Jewelry
Pandora Charms
Jordan 1's
Adidas Canada
Air Jordans 1
Moncler Sale
Asics Sneakers For Women
Jordan 1 Retro
Jordan 1 Retro
New Nike Shoes
Pandora
Air Jordan 1
Pandora Official Site
Ferragamo Belt
Air Jordan 1 Low
Nike Outlet
Nike Factory
Nike Outlet Online
Yeezy
Pandora Jewelry
Asics Outlet Online
Nike Store
Pandora Charms
Pandora Charms
Nike
Pandora Bracelets
Moncler Jackets Men
Balenciaga
Yeezy 350
Pandora Charms
Moncler Outlet
Best Nike Running Shoes
Moncler Factory
Pandora Rings Official Site
Ferragamo Shoes
Adidas Shoes
Balenciaga Triple S
Adidas
Yeezy Shoes
Nike Men Shoes
Adidas Store
Jordan 1 Retro High
Pandora Bracelets
Pandora Bracelet
Pandora Jewelry
Nike Outlet Canada
Nike Shoes
Cheap Moncler Jackets
Adidas Men's Shoes
Moncler Jacket For Men
Pandora Outlet
Pandora Outlet
Nike Canada Online
Charms Pandora
Nike Shoes
Pandora Charms
Balenciaga Outlet
Adidas Shoes Women
Asics Running Shoes For Women
Pandora Charms
Pandora Charms Jewelry
Nike
Adidas Canada
Nike Air Jordan 1
Nike Shoes For Women
Pandora Charms
Pandora Jewelry
Pandora Jewelry
Pandora Jewelry Official Site
Jordan One
Nike Canada
Air Jordan 1 Low
Women Nike Shoes
Balenciaga Sale
Pandora Outlet Online
Nike Outlet Store Online Shopping
Puma Store
Pandora Jewelry
Nike Sneakers For Men
Air Max 720
Jordan 1
Men's Nike Shoes
Asics Shoes
Pandora Jewelry Outlet
Pandora Ring
Adidas NMD
Nike Outlet
Asics Shoes
Pandora
Salvatore Ferragamo
Moncler Outlet
Moncler Coat
Cheap Nike Shoes
Yeezy
Nike Snkrs Canada
Air Jordan 1 Retro
Balenciaga
Ferragamo
Pandora Bracelet
Wholesale Retro Jordans
Asics Gel Kayano
Pandora Bracelets
Goyard Handbag
Nike Shoes
Pandora Jewelry
Pandora Jewelry
Pandora Jewelry
Pandora
Pandora
Nike Shoes Canada
Pandora Jewellery
Moncler Coats Outlet
Pandora Outlet
Pandora Bracelets
Nike Canada Outlet
Wholesale Jordan Shoes
Pandora
Pandora Charms
Adidas Sale
Pandora Charms Sale Clearance
Pandora Jewelry
Ferragamo Belt
Adidas Shoes
Pandora Outlet
