67 100 watt cap board layout
Post by VelvetGeorge » Fri Aug 19, 2005 12:39 am
Here's a typical 67 cap board. Later the 32uf caps became 100uf as well.
67 100 watt cap board copy 2.jpg (80.08 KiB) Viewed 11232 times
67 100 watt cap board copy.jpg (272.9 KiB) Viewed 2207 times
Post by VelvetGeorge » Mon Jan 16, 2006 6:29 pm
Here's a pic of the bottom of a 12 series board I just wired. I thought this would be useful.
cap board bottom wiring.jpg (62.41 KiB) Viewed 10746 times
rockstah
Post by rockstah » Mon Jan 16, 2006 6:30 pm
george can you show us the top of that board also?
Guitar Adjuster
Post by Guitar Adjuster » Mon Jan 16, 2006 6:33 pm
Thanks George, this is a life saver. I appreciate your help with my 12xxx build.
Allen
Post by VelvetGeorge » Mon Jan 16, 2006 6:41 pm
Sure.
Allen, your email is what prompted me to take these pics. Glad they help.
VG
cap board.jpg (64.77 KiB) Viewed 10730 times
rockstah
Post by rockstah » Mon Jan 16, 2006 6:42 pm
excellent!
i notice the diodes are in a different direction as Dan's layout - but it still works the same. is the way you have it more true?
Mark
BrownSound1
Post by BrownSound1 » Tue Jan 17, 2006 1:21 am
Allen saved me an email! :D Thanks George for posting that.
Why is it we can remember where all the wires go, but can never find a pick?
Guitar Adjuster
Post by Guitar Adjuster » Tue Jan 17, 2006 1:02 pm
George,
Just so I get this correct on the wiring....the Red wire on the board goes to the HT Fuse, Yellow goes to the PT Common, Black goes to ground somewere under the board?
Thanks,
Allen Jones
Post by VelvetGeorge » Tue Jan 17, 2006 1:15 pm
Yellow is the PT secondary center tap.
Run your ground over to the filter cap can mounting bolt.
Guitar Adjuster
Post by Guitar Adjuster » Tue Jan 17, 2006 1:28 pm
The yellow secondary tap on the Hayboer PT is also a Yellow wire between the 2-blue (heater) and white (bias) wires? According to the diagram it has 0 va/c? Correct? I just don't want to blow this thing up first time I turn it on :)
Post by VelvetGeorge » Tue Jan 17, 2006 1:30 pm
That's correct.
Post by VelvetGeorge » Tue Jan 17, 2006 1:38 pm
A new diagram.
VG
cap board wiring 2.jpg (58.98 KiB) Viewed 10660 times
rockstah
Post by rockstah » Tue Jan 17, 2006 1:42 pm
thanks george!
bluze81
Post by bluze81 » Tue Dec 26, 2006 12:04 am
VelvetGeorge wrote:Sure.
VG
George what brands and values are these caps in the picts,bluze
rockstah
Post by rockstah » Tue Dec 26, 2006 1:17 am
two ( black) F&T 100u caps
and two ( blue) BC 33u
