New 50 lead spec
New 50 lead spec
Hi all. thought i would post some photos of my new 50watt done to 68 lead specs. has marstran power & output trannies sozo vintage caps & carbon comps on one of Brians turret boards. taken me about a month to get all the parts over to Australia but well worth the wait. turned out great & sounds awesome cant wait for it to break in a bit.
- (133.66 KiB) Downloaded 1472 times
- (136.92 KiB) Downloaded 1471 times
- (127.3 KiB) Downloaded 1471 times
- _IGP1251.jpg (155.81 KiB) Viewed 2363 times
- Flames1950
- Big Mike
Re: New 50 lead spec
That does look very nice.
Curious about he bias pot install. I did mine to the kit instructions exactly.
Not understanding the difference. Can you elaborate?
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
Scumback Speakers
thanks guys. the bias pot i had was a vertical mount that only had 3 terminals so i used a piece of buss wire for the ground side then joined the resistor to th 3rd leg. i also used the Larry style grounding in this amp & it worked great dead quiet you have to put ear to speaker to tell that it even on.
Looks incredible, well done!
- reggyboy1970
That looks gorgeous... i bet it sounds awesome cranked up!
- Doug H
Looks good, couple caps on backwards
Looks like it might be tricky to get a screw driver on that bias pot.
And where can I see the "Larry Grounding scheme", it's some kind of star ground I assume, is there a diagram somewhere?
i used the grounding scheme in jtm45 forum that uses individual star points across the front of the chassis & 2 near the filter caps. i left the ground points for the power tube cathodes at the sockets though. after doing a bit of reading i decided to go with a random orientation with the caps.
- Doug H
got it, cool thanks
