New Build: JTM45 VSoZo ABCC LarMar IEC LarrysGnd Turret Fuse
ldanmartin
Post by ldanmartin » Wed Sep 15, 2010 9:00 pm
I am in the process of a new JTM45 build:
Contents/Modifications:
JTM45 Metro Kit
Vintage Sozo Capacitors
Allen Bradley NOS Carbon Composition Resistors
Lar/Mar PPIMV
IEC Power Receptacle
Larry's Grounding
Kurts Equipment / Brian Haberman Turret Board & Fuse Holder
I have never built an Amp before. Please feel free to comment and point out any mistakes as I go along.
Questions:
1) The original kit instructions on Step#8 says to use 20 gauge bus wire to the ground lug on the Internal Filter Cap... but I used the black 22 gauge kit wire as I needed to go farther away to Larry's Grounding point#3. Is the 22 gauge wire going to be ok for that?
2) Larry's Grounding point#5 indicates five items should be connected there... but I only see four connections on most peoples pictures. Items to connect: Screen Filter, Main Filter, HV CT (via fuse), V4 & V5 Cathodes (1R bias resistors).
I believe the Main Filter is the F&T dual 32uf can cap mentioned in Step#3. Where is the "Screen Filter" and what step is that mentioned in the instructions?
Thank you MetroAmp and the forum members for all the insight (I have read for days before I bought a kit, and before/during this build process). This is a fun kit to build!
Dan Martin
Re: JTM45 VSOZO ABCC LAR/MAR IEC ALT GROUND TURRET FUSE
Post by Flames1950 » Wed Sep 15, 2010 10:20 pm
The 22awg wire will be fine.
I'm guessing most guys connect the two power tube cathodes together before making a single run to the grounding point; that's how I've implemented this before anyway. I think I used some buss wire and sleeving between the tubes, then the black 22awg wire from V5 to the ground lug, but I'd have to walk twenty feet away from my computer and turn an amp over to be sure, and it is getting late.............
OK, talked me into it, and that is what I did. :wink:
ldanmartin
Post by ldanmartin » Wed Sep 15, 2010 10:42 pm
I started by drilling some holes for the Lar/Mar PPIMV & IEC Power Receptacle:
http://img824.imageshack.us/i/dsc0002vu.jpg/" onclick="window.open(this.href);return false;
http://img808.imageshack.us/i/dsc0020p.jpg/" onclick="window.open(this.href);return false;
http://img828.imageshack.us/i/dsc0032e.jpg/" onclick="window.open(this.href);return false;
http://img713.imageshack.us/i/dsc0033ei.jpg/" onclick="window.open(this.href);return false;
http://img69.imageshack.us/i/dsc0034w.jpg/" onclick="window.open(this.href);return false;
http://img245.imageshack.us/i/dsc0036vw.jpg/" onclick="window.open(this.href);return false;
http://img543.imageshack.us/i/dsc0037so.jpg/" onclick="window.open(this.href);return false;
http://img827.imageshack.us/i/dsc0040wk.jpg/" onclick="window.open(this.href);return false;
I ran 22AWG from V4 to Ground#5, and 22AWG from V5 to Ground#5... not bus wire... (I originally went from V4 to V5, then V5 to ground#5)?
Thanks,
Dan
Post by Flames1950 » Wed Sep 15, 2010 10:49 pm
Sure, that's fine too!
ldanmartin
Post by ldanmartin » Thu Sep 16, 2010 12:51 am
Is there a "Screen Filter" on a JTM45?
Where is it on this image connected to ground#5?
Ground connection #5 has 5 connections:
5) Screen Filter, Main Filter, HV CT (via fuse), V4 & V5 Cathodes (1R bias resistors)
http://img820.imageshack.us/i/grounding20scheme1.jpg/" onclick="window.open(this.href);return false;
Just checking.
Dan
ldanmartin
Post by ldanmartin » Thu Sep 16, 2010 1:50 am
I want to remove this extra ground lug I have in my build that incorporates Larry's Grounding point#5 (if there is no additional Screen Filter or additional Main Filter ground wire to run).
I want to remove the extra ground lug in the upper left of this picture if I have nothing else to solder there:
Dan
ldanmartin
Post by ldanmartin » Thu Sep 16, 2010 1:59 am
arledgsc
Post by arledgsc » Thu Sep 16, 2010 10:46 am
The confusion is the large Main and Screen filter capacitor connected at Larry GND #5 share the same grounding wire to the solder lug. So a single ground connect covers both since the capacitor package connects the ground for each capacitor side internally. Think of it as Main/Screen filter,....
You are doing a great job BTW. Keep those questions coming and we'll be happy to answer them (if we can!) Scott
Metro JTM45, Metro 50W Lead, JTM50 Black Flag, and Ceriatone 18W TMB
Scumback M55/M75, Ceriatone C-lator
ldanmartin
Post by ldanmartin » Thu Sep 16, 2010 9:27 pm
Thanks for the info Flames1950 and Scott, and for the encouragement!
I have removed the extra ground lug from point#5.
Pot's installed, input jacks installed and wired.
ldanmartin
Post by ldanmartin » Sat Sep 18, 2010 7:46 am
Working on the PTP board now...
ldanmartin
Post by ldanmartin » Tue Sep 21, 2010 6:11 am
Since I am working in the garage, this is taking a while, as it's still hot in the Phoenix Arizona Metro area. It was 100 degrees in the garage tonight at 8PM when I started (90 at 2AM). Making progress. Here are some more pics:
(Large images):
http://img412.imageshack.us/i/dsc0052hq.jpg/" onclick="window.open(this.href);return false;
http://img189.imageshack.us/i/dsc0054yn.jpg/" onclick="window.open(this.href);return false;
http://img704.imageshack.us/i/dsc0057nw.jpg/" onclick="window.open(this.href);return false;
http://img684.imageshack.us/i/dsc0058cfz.jpg/" onclick="window.open(this.href);return false;
http://img641.imageshack.us/i/dsc0059oo.jpg/" onclick="window.open(this.href);return false;
http://img641.imageshack.us/i/dsc0060gu.jpg/" onclick="window.open(this.href);return false;
http://img534.imageshack.us/i/dsc0061lzs.jpg/" onclick="window.open(this.href);return false;
http://img831.imageshack.us/i/dsc0062d.jpg/" onclick="window.open(this.href);return false;
http://img411.imageshack.us/i/dsc0063gs.jpg/" onclick="window.open(this.href);return false;
http://img62.imageshack.us/i/dsc0064ym.jpg/" onclick="window.open(this.href);return false;
Here are some in a smaller format:
ldanmartin
Post by ldanmartin » Tue Sep 21, 2010 6:12 am
Here's some more:
ldanmartin
Re: NEW BUILD: JTM45 VSOZO ABCC LARMAR IEC LARRYSGND TURRET
Post by ldanmartin » Tue Sep 21, 2010 11:37 am
How do you clean the inside of the chassis, parts and solder joints?
1) Can of air?
2) Deoxit? (What do you do, spray the whole inside and let it dry? Where do you get it from?)
3) Isopropyl Alcohol?
4) Other ideas?
Thanks in advance,
Dan
ledzep443
Post by ledzep443 » Tue Sep 21, 2010 5:29 pm
ldanmartin wrote:How do you clean the inside of the chassis, parts and solder joints?
1) Can of air?
4) Other ideas?
Thanks in advance,
Dan
Isopropyl Alcohol and an acid brush.
ldanmartin
Post by ldanmartin » Wed Sep 22, 2010 1:54 am
Thanks LEDZEP443!
I went and got the Isopropyl Alcohol and an acid brush (I'll use them at the end, after populating the PTP board).
More pics, pots wired:
