69 Superlead Build Diary
harkkam08
Post by harkkam08 » Wed Jan 19, 2011 5:48 am
Hey guys just before George Shut the store down I bought one of the last kits so here is my build diary hoping to get some reviews, tips and comments on whats good and what could use some improvement.
I am putting in
Piher/Iskra Resistors
NOS Mustards/ Hunts Erie and Lemco
Mullard Reissues in all preamp tubes
Some vintage cloth covered solid wire :)
Metal Panels
Its a hybrid monster here are some pics
(235.96 KiB) Downloaded 2105 times
(241.13 KiB) Downloaded 2105 times
harkkam08
Re: 69 Superlead Build Diary
Post by harkkam08 » Wed Jan 19, 2011 5:49 am
more pics
(258.83 KiB) Downloaded 2104 times
(269.29 KiB) Downloaded 2104 times
harkkam08
Post by harkkam08 » Thu Jan 20, 2011 11:27 am
Hey guys is it okay to use 1/2 watt resistors for the filters?
FourT6and2
Post by FourT6and2 » Sun Jan 23, 2011 12:06 pm
What's with the 10 watters on the power tubes? Those are huge. Everything looks ok so far, I'd twist the OT secondaries and the way you have the OT primaries routed (to the front of the chassis and then back to the sockets) may cause some noise issues with the pots and presence circuit. But, I'm not sure.
The resistors you've used on the filtering cans are a waste, in my opinion. Just some metal-film will work fine. I used something like 200-300k here to reduce ghosting. But it's up to you. And I'd use something higher than 1/2 watt.
As a reference, you can check out all my build photos here: http://haftelm.deviantart.com/gallery/?catpath=scraps" onclick="window.open(this.href);return false;
harkkam08
Post by harkkam08 » Tue Jan 25, 2011 1:09 am
Hm.. thanks.
The 1/2 watt filter resistors isnt that the rating marshall used?
I was looking at their schematic and all resistors unless labeled are 1/2 watt
avguy49
Post by avguy49 » Tue Jan 25, 2011 8:07 am
Screen/Grids are rated at 1K 5W and everything else is 1/2 watt I believe.
My $0.02
~Avguy49
~Philly
http://www.wrightamps.com
Post by neikeel » Tue Jan 25, 2011 2:35 pm
harkkam08 wrote:Hm.. thanks.
No, the resistors on the filter cans are at least 1w and possibly 2w. It is arguable that 56k is too low a value and 220k is probably better.
VintageCharlie
Post by VintageCharlie » Thu Jan 27, 2011 10:00 am
I'm pretty sure they put 2w on the filter cans - it's the only place i see original 2 watters on the old Marshalls (i have been looking for 2w 56k's for this purpose for quite some time, but never found any). I don't know if 1w would be enough, but 1/2w certainly sounds very risky. Also, Marshall didn't spend a cent where it's not needed, so i guess the 2w resistors on the filter cans is a minimum - they'd have used 1w, if it worked ok, as these would be cheaper. Please correct me if i'm wrong, as i'm interested in this too, but i have seen only 2w in these spots.
1w for the power supply resistors and on the preamp filter can is correct.
Good luck on the build! Looking forward to further pics :)
Regards,
VintageCharlie
rockstah
Post by rockstah » Thu Jan 27, 2011 12:30 pm
2watt resistors are here - http://www.surplussales.com/Resistors/C ... Comp_5.htm" onclick="window.open(this.href);return false;
Mark
Post by neikeel » Thu Jan 27, 2011 1:00 pm
I have been keeping my eyes open for these too.
Philosophically you have to wonder why Marshall put these on the screen caps other than to help discharge the caps to earth. If they were on the mains caps you could understand a sthey help balance the voltage between the series aspect of the cans either side of the centre tap. You don't really need them there at all and I would tend not to use them if I have 500v rated cans.
VintageCharlie
Post by VintageCharlie » Thu Jan 27, 2011 1:09 pm
Would it be safe to go with 2w cc's as opposed to cf's? I might go with AB cc's for this purpose if yes. Thanks!
VintageCharlie
Post by VintageCharlie » Thu Jan 27, 2011 1:14 pm
Btw. what value 2w resistor should i use on dual 32uF caps. It's 56k for the dual 50uF's - would it be the same for 32uF dual caps or should it be lower/higher?
Post by neikeel » Thu Jan 27, 2011 1:54 pm
VintageCharlie wrote:Btw. what value 2w resistor should i use on dual 32uF caps. It's 56k for the dual 50uF's - would it be the same for 32uF dual caps or should it be lower/higher?
Depends upon what you are trying to achieve :wink:
VintageCharlie
Post by VintageCharlie » Thu Jan 27, 2011 2:08 pm
I want to achieve that the whole thing doesn't blow up in the first place :D
I'm asking because i have never seen what Marshall used on the 32/32uF filter caps that can be seen on some 68 100w's - SL's and SB's - i guess the resistors are always beneath the board as i haven't seen anything on the top, but afaik, there has to be something between them?
I'd be interested in the value originally used by Marshall - not going after any specific "effects" :)
Post by neikeel » Thu Jan 27, 2011 2:59 pm
VintageCharlie wrote:I want to achieve that the whole thing doesn't blow up in the first place :D
Nope the early amps with cap boards did not use them.
They appeared with the 69 all caps up top amps.
I do not think you need them, and if you do decide to put some on you will find 220k better as they will discharge slower and be less likely to cause ghosting.
