used the Metro amp instructions.
Used Magnetic components xformers from Triode. good company!
Big B+ voltage of around 464v. i earlier posted that it had been at 485v but that was before the Kt66 was added.
Rocking a bias of 38ma on one Kt66 and 45ma on the other using a 100k 2 watt resistor as my bias resistor.
Lots of voltage to the ecc83s too. Maybe too much. 20% above spec.
used JJ 32uf+32uf cap
used ARS 16uf+16uf cap
used Valve Art KT66
used Harma ecc83/JJ ECC83 and some other Ecc83
used Sprague Atom 16uf 475 cap and 8uf Sprague Atom caps
Used sozo caps
Used 1w carbon composite resistors where needed.
no allen bradley nonsense.
I have a 1961 vox Ac30 and this Marshall sounds every bit as good through a Marshall 2 12 cab with Celestion Vintage 30 speakers
wired for 16ohm,
Loving this amp so much. Very Fender. Very Fender sounding.
Thanks everyone
michael de a
