PT 1202-55 Marstran
OT 784-103 Marstran
getting B+ 365 standby switch
getting 388 at pin 3 of power tubes
bias current at 1 ohm resistors 180 power tubes will start to
replate after short time.
new jtm 45 trouble
- tooloud
new jtm 45 trouble
"Bend it till it sounds good"
18 Watt TMB Head
JTM45 clone
Metro 69 100 Watt
50 Watt Ceritone metro mix
2X12 Straight & Slant Stack
4X12 V30's & G12H30's
BF Champ
18 Watt TMB Head
JTM45 clone
Metro 69 100 Watt
BF Champ
Re: new jtm 45 trouble
1) Is your bias circuit grounded?
2) Check the ground on your output socket
3) That PT would normally have a 150k or 180k resistor before the diode
Oh and your bias caps are back to front!!
- tooloud
bais caps were in backwards.... bias current correct now.... B+ now 422
18 Watt TMB Head
JTM45 clone
Metro 69 100 Watt
BF Champ
18 Watt TMB Head
JTM45 clone
Metro 69 100 Watt
BF Champ
tooloud wrote:bais caps were in backwards.... bias current correct now.... B+ now 422
