Clyde Mccoy Wah Circuit Board
axeman
Post by axeman » Fri Oct 26, 2012 8:53 pm
Can anyone here build this for me?
axeman
Re: Clyde Mccoy Wah Circuit Board
Post by axeman » Wed Oct 31, 2012 6:52 pm
Can some one ID these two parts.
clyde2 red cir.jpg (50.72 KiB) Viewed 3284 times
SteadyEddie
Post by SteadyEddie » Thu Nov 01, 2012 8:39 pm
Polystyrene caps. They should be .01 if I'm not mistaken.
axeman
Post by axeman » Thu Nov 01, 2012 8:52 pm
Are they axial or radial?
SteadyEddie
Post by SteadyEddie » Thu Nov 01, 2012 9:22 pm
axeman wrote:Are they axial or radial?
They should be whatever fits best on your pcb. That said, when I did my build, I got my styrene caps from Mouser, and they only had .01 caps in radial.
axeman
Post by axeman » Tue Jan 22, 2013 6:30 pm
axeman wrote:Can some one ID these two parts.
Can anyone help me find these caps. I should be done soon.
Miss this place.
axeman
Re: Clyde Mccoy Wah Circuit Board Update
Post by axeman » Fri Mar 01, 2013 12:04 am
Finally, but theirs one problem. It doesn't work. Does anyone know if the location were the mustards are at, need to be Electrolytic?
(8.99 KiB) Downloaded 1165 times
frenchie
Post by frenchie » Fri Mar 01, 2013 3:53 am
nope ...they don't need to ;
http://img255.imageshack.us/img255/1051 ... 458896.jpg" onclick="window.open(this.href);return false;
axeman
Post by axeman » Fri Mar 01, 2013 7:12 am
For some reason I can't get it to work I replaced the B109b Transistors twice, I tipled checked the wiring and measured the halo inductor. :what:
frenchie
Post by frenchie » Fri Mar 01, 2013 1:35 pm
^^ you checked or MEASURED your wiring ? .... if it's not solid core wire ( honestly on pedals i think it's a must ) i strongly advise to do so .... if you did .... well then .... could be anything ....
ps : your wiring looks good at first glance :what:
axeman
Post by axeman » Fri Mar 01, 2013 1:48 pm
I checked the wiring conection, and I'm getting good connection. The wie I'm using is PTEF wire 24g. The Pot is a PEC 100K-A, I've used PEC Pots in my second wah and it improved the tone ten times compared to the Dunlup pots.
Alnico
Post by Alnico » Fri Mar 01, 2013 3:53 pm
Are you sure the transistors are installed correctly? With Q1, you will have to cross over the base and collector - the board connections are e c b left to right as seen in your photo. Q2 is e b c top to bottom. The tag on the case denotes the emitter.
If you're certain they're correct, can you post the voltages on each leg?
spaceace76
Post by spaceace76 » Fri Mar 01, 2013 5:56 pm
some more info would help. measure the voltages at all pins of each transistor, check that the board is getting power from the battery, double check the component values you used, wiring looks okay however you may want to simplify the grounding and keep everything at one spot.
what doesn't work exactly? does the pedal pass signal? does it act like a volume pedal? do you just get no signal whatsoever?
axeman
Post by axeman » Sat Mar 02, 2013 12:55 am
Alnico wrote:Are you sure the transistors are installed correctly? With Q1, you will have to cross over the base and collector - the board connections are e c b left to right as seen in your photo. Q2 is e b c top to bottom. The tag on the case denotes the emitter.
O.k. as far as the transistors go, I followed a layout that a friend sent me. The layout has component values and transistor positioning. I'm in Las Vegas right now, so when I get back home I'll post the Layout.
axeman
Post by axeman » Sat Mar 02, 2013 12:59 am
spaceace76 wrote:some more info would help. measure the voltages at all pins of each transistor, check that the board is getting power from the battery, double check the component values you used, wiring looks okay however you may want to simplify the grounding and keep everything at one spot.
The battery/power is fine. I'll post the Layout on Sunday and take some measurements.
Spaceace 76
WAh v846 wring.pdf
(32.44 KiB) Downloaded 207 times
