Hey, so am just finishing up a bassman build and I am looking into ways to actually use it.
Currently in a small house so can't have too many cabs, but after a bit of searching I found the Aiken schematic for the two head switcher that has the input switch in it (attached to post).
I have only worked off layouts and simple schematics before, so I don't know how these relays all work. Does anyone have a good place to start in turning this into a point - to - point or PCB?
I already have a bunch of 16ohm, 8ohm and 4ohm 100Watt power resistors sitting around and all the rest looks easy to get in terms of parts. And if it comes up, I only have a 2x12 Jcm800 cab so can't do the twin speaker split trick.
Cheers
Age old Head Switcher project
- HeadSwitch.pdf
- (17.45 KiB) Downloaded 129 times
Re: Age old Head Switcher project
Relays are simple devices. They're switches. You put voltage across the coil, and the switch engages. You usually have a spdt or a dpdt relay. So the signal goes into the "common" side and there's a normally open (open with no voltage) and normally closed side.
Oh the relays he suggests what you say are the ones to get? and mounting them in a handwired setup?
