Inside Look at the Dr. Z Brake Lite Attenuator
chrisom
Post by chrisom » Sun Jun 22, 2014 12:44 pm
Somebody posted this on CL... Resistive load?
Dr Z Attenuator Guts JPEG.JPG (41.76 KiB) Viewed 11866 times
Dr Z Attenuator JPEG.JPG (36.03 KiB) Viewed 11866 times
Re: Inside Look at the Dr. Z Brake Lite Attenuator
Post by neikeel » Mon Jun 23, 2014 5:25 am
chrisom wrote:Somebody posted this on CL... Resistive load?
Yes - not an ideal situation should be safe tho'.
How does it sound?
N3m0 7h3 Fi5h
Post by N3m0 7h3 Fi5h » Mon Jun 23, 2014 10:57 am
I found a lot of similarities to an image of the guts of a real genuine Airbrake that I found at ampgarage couple years back..
Post by neikeel » Mon Jun 23, 2014 11:26 am
Also no heat sink or fan, mmm toasty!
chrisom
Post by chrisom » Mon Jun 23, 2014 12:15 pm
How does it sound?
I didn't purchase it, just saw the ad and was wondering about it. I did however buy one of those huge 300w, 8-ohm wirewound resistors that were on eBay a while back...
http://forum.metroamp.com/viewtopic.php ... stive+load
I wondered if I could construct a similar circuit using my huge wirewound? I may be wrong, but from what I've seen of these, I think with the Brake Lite the chassis IS the heatsink, and it bolts hanging on the inside of the rear a combo amp, to dissapate the heat. The huge wirewounds from eBay sounded surprisingly good, from the soundbytes posted... :listen:
N3m0 7h3 Fi5h
Post by N3m0 7h3 Fi5h » Mon Jun 23, 2014 6:53 pm
chrisom wrote:I wondered if I could construct a similar circuit using my huge wirewound?
This would be accurate real genuine Airbrake schematic ..
http://i2.photobucket.com/albums/y50/PR ... or1_a1.png
Airbrake Pictures :
http://www.src.strayca.com/images/Atten ... side_1.JPG
http://www.src.strayca.com/images/Atten ... side_2.JPG
Other Attenuator .. Weber Mass :
http://www.webervst.com/mass.gif
beaulieu
Post by beaulieu » Thu May 18, 2017 1:48 pm
I built both an lite and airbrake... You can buy same parts and rather inexpensive. They sound pretty good
69 SuperBass Plexi
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
2550 Silver Jub stack
71 LesPaul Deluxe
68,71,73 4x12
black nebula
Post by black nebula » Fri Feb 15, 2019 3:26 am
Could you please list all necessary parts numbers/articles for both? I'd like to build one myself
