SO does it have the TONE
! see post under general evh
Last edited by topsportsmanta1 on Tue Dec 01, 2015 5:44 pm, edited 2 times in total.
mike
- efraser68
Re: SO does it have the TONE
What era are you aiming for? Too much preamp gain for early Roth era. It sounds like an EVH 5150 iii series or maybe the new MXR pedal
Tell us what the amp is and what you want to achieve and more folks will chime in.
![Confusion :what:](./images/smilies/confused.gif)
Thanks eric for taking a listen
its first time ever trying to record this amp it is a rockstah mod 6 that mark had come up with , retains the same tone no matter were the volume is , it sounds like sean mcflys in person but recording it it changes bad , I think maybe it was mic placement , n what I am using that im loosing the tone , I am going sm57 into pa system out to a behinger sca202 then into computer thru junkie audacity any help would be much appreciated here is the hardware n settings I used
- (371.06 KiB) Not downloaded yet
- (35.22 KiB) Downloaded 456 times
- (53.69 KiB) Downloaded 456 times
mike
Settings
- (388.23 KiB) Not downloaded yet
mike
- Strat78
If by "tone" you mean Glenn Tipton's, then yes.
What's up with that MM tranny using Marks moniker? What is the story behind that!![Shocked :shock:](./images/smilies/icon_eek.gif)
![Rock :rock:](./images/smilies/devilshorns.gif)
