bypass cathode with cap and resistor..why?
giordydiver
Post by giordydiver » Fri Jan 15, 2016 10:07 am
hi guys looking afd100 schematic i have seen that the valve of afd mode has a bypass cathode formed by a cap in series with a resistor.. why use? ho cut off hight frequences?
Haze13
Re: bypass cathode with cap and resistor..why?
Post by Haze13 » Fri Jan 15, 2016 11:05 am
For AC the cap is a short circuit, so AC load line formed by a resistance of the 2 values in parallel... Of course very low frequencies are being filtered out.
giordydiver
Post by giordydiver » Fri Jan 15, 2016 12:47 pm
if i understand in this way i have more gain but a fat and bass tone
Haze13
Post by Haze13 » Sat Jan 16, 2016 4:25 am
1/(2*Pi*r*C) = -3dB cut off frequency. r is a cathode resistor in parallel with a output cathode resistance (rk) of a tube.
rk= (RL (plate resistor) + ra (anode resistance of a tube )/(Mu + 1)
giordydiver
Post by giordydiver » Sat Jan 16, 2016 8:08 am
ok but which frequencies? hight or low?
Haze13
Post by Haze13 » Sat Jan 16, 2016 10:09 am
Put the values in the formula and calculate:) I don't know what cap and resistance are being used there...Most likely that a very low frequencies will be filtered out.
giordydiver
Post by giordydiver » Sat Jan 16, 2016 12:53 pm
Ok, with 100n and 10k in series cutt off is at 83hz, but are cutted off frequencies over these or undere these? Sorry but i dont known a lot of theory
Haze13
Post by Haze13 » Sat Jan 16, 2016 1:05 pm
Lower = Under :)
