On/on switch specs
dan_tramble
On/on switch specs
Post by dan_tramble » Tue May 31, 2016 11:20 am
Hi guys
I want to make coupling cap channel 1 switchable from a .022 to a .0022. What voltage rating switch should I use?
Common ones at the electronics shop are 125v 6 amp
Please post to thread
Thanks. Dan
MetroAmp addict!
JTM 50/45,1987's & 1986
1959 and 2203/2204 Amps
1974 amp
Can't stop building, very addictive!
Re: On/on switch specs
Post by Roe » Tue May 31, 2016 2:54 pm
Switch after the cap and it is no problem. Switching the anode is a bad idea, unless you find a switch rated for 500v DC
