JCM 800 Input Problem
- Dax-The-Ax
I was playing my JCM 800 through the high input and the sound started crackling in and out and finally, with the amp cranked, i can barely hear any sound, it is very faint. The low input works fine. Anyone have any suggestions, the amp is from 86' and has the frickin inputs and tone controls mounted on the PCB!! Ugh!!!
- VelvetGeorge
- Site Owner
- Flames1950
Hey Dax, you may need to change the low input jack as well. MV amps use the switching contacts of the low input jack to make a connection between the first and second gain stages for the high input, when you stick a plug into the low input the first gain stage is now disconnected. If those contacts are dirty or bad you will not pass signal to the second gain stage using the high input anymore but your low input will still work fine. If you still have the jack you took out swap it back in for the low input and see if it helps.
- Dax-The-Ax
Dax
Thanks, i will try that out, these Board mounted pots and jacks are a joke! I'm very close to yanking the board , jacks and tone controls out and converting to Superlead PTP!! It's a modded bastard, anyway. It has an added effects loop, which i like, but haven't decided if i will keep it yet.
- Dax-The-Ax
- Dax-The-Ax
