Late '68, early '69 restoration
Post by VelvetGeorge » Wed Jun 28, 2006 9:22 pm
I've been taking pics along the way so I thought I would show the restore process on this amp.
It's an early example of the later plexi 100 layout, with all six filter caps on top. The serial # is 10XXX, not to be confused with the earlier 10XXX amps in late '67. Thanks Marshall...
This one has been around, if only it could talk. Then again, it might just scream "NOoooooooooo".
The trannys are not original, unfortunately. But the choke probably is. It's era correct at the very least. Part #C1999 and measures exactly 5H.
The chassis has lots of extra holes as you can see. So does the rear plexi panel. The front is actually in good shape, no extra holes or cracks.
Lots of replaced parts in there.
DSC00192 copy.jpg (67.96 KiB) Viewed 94704 times
DSC00187 copy.jpg (60.85 KiB) Viewed 94709 times
Post by VelvetGeorge » Wed Jun 28, 2006 9:24 pm
Here's a closer shot of the board and extra tube section.
VG
DSC00190 copy.jpg (74.92 KiB) Viewed 94700 times
Post by VelvetGeorge » Wed Jun 28, 2006 9:27 pm
Well, the more I removed, the more obvious it became that I needed to start almost from scratch.
The choke was in the wrong place, the transformers needed to be removed to have wires replaced and routed correctly, the tube sockets are being replaced.......
So it went on the chassis jig and off came the parts.
VG
DSC00236 copy.jpg (60.05 KiB) Viewed 94681 times
DSC00241 copy.jpg (73.52 KiB) Viewed 94690 times
Post by VelvetGeorge » Wed Jun 28, 2006 9:30 pm
The board components were all removed so I threw it on the scanner.
Pure art.
VG
(60.86 KiB) Downloaded 13664 times
Post by VelvetGeorge » Wed Jun 28, 2006 9:43 pm
Making progress on the reassembly.
Each part gets cleaned with solvent and a detailing brush before being reinstalled. I spent a lot of time cleaning the chassis too.
DSC00245 copy.jpg (56.1 KiB) Viewed 94656 times
DSC00250 copy.jpg (72.09 KiB) Viewed 94662 times
5150loveeddie
Post by 5150loveeddie » Wed Jun 28, 2006 10:54 pm
Cool I did the same on a 50watt........metal face....let me find the pics
Post by Flames1950 » Wed Jun 28, 2006 11:34 pm
Jesus, that chassis looks like swiss cheese....how many different OT's have been on that thing??
I really appreciate that only six holes were added to my Super PA chassis now.
Bainzy
Post by Bainzy » Thu Jun 29, 2006 6:21 am
Are you gonna put a new Metroamp OT in there?
Shred Guitar
Post by VelvetGeorge » Fri Jun 30, 2006 3:13 am
We're sticking with the OT that's been on the amp since the late 70's for now.
Here's the latest progress.
VG
DSC00270 copy.jpg (78.2 KiB) Viewed 94593 times
Post by VelvetGeorge » Fri Jun 30, 2006 7:14 pm
I managed to finish all the wiring and fire this amp up: I'm really happy with the results!!! I wasn't sure about the OT, but I don't see any reason to change it.
I haven't put the strapping on the wires yet, or put the knobs back on. But otherwise, I'm done.
DSC00292 copy.jpg (75.49 KiB) Viewed 94550 times
Post by VelvetGeorge » Fri Jun 30, 2006 7:17 pm
How about a nice before and after shot?
VG
DSC00296 copy.jpg (70.87 KiB) Viewed 94529 times
DSC00190 copy 2.jpg (75.56 KiB) Viewed 94539 times
Post by VelvetGeorge » Fri Jun 30, 2006 7:18 pm
One more.
VG
DSC00283 copy.jpg (65.31 KiB) Viewed 94503 times
Guitar Adjuster
Post by Guitar Adjuster » Fri Jun 30, 2006 7:34 pm
Looks great George, did you put in new cap cans?
OnTheFritz
Post by OnTheFritz » Fri Jun 30, 2006 7:47 pm
That was really cool to see, well done! :wink:
Bet it sounds great!
Late '68 restoration
Post by yngwie308 » Fri Jul 07, 2006 2:18 pm
You do beautiful work George,it warms my heart being an old electronics tech/wireman,to see such painstakingly intricate work.
You are indeed a master,no doubt.
Regards
Yngwie308
