I looked at these circuit diagrams of the JTM45:
![Image](http://homepage.ntlworld.com/s.castledine/greenfuz/jtm/jtm45lyt.png)
![Image](http://www.ceriatone.com/images/layoutPic/marshallLayout/JTM45ceriatone.jpg)
![Image](http://marstran.com/66JTM45Schematic.gif)
plus attachment.
Some questions about the found differences:
1. Why are often two 10uF capacitors are used instead of 8uF like in the marstran.com schematic ?
2. Why I can find a 25K/22K resistor under the 56K resistor or only the 56K resistor next to the both 10/8 uF capacitors ? Which combination is right ?
3. I also found a 1K2W and a 8K2 2W resistor instead the 10K resistor next to the both 10/8 uF capacitors ? Which combination is right ?
4. I found a 220uF or 250uF resistor near 820 ohms resistor. Which combination is right ?
5. Why is there sometimes a 180K or a 150K resistor under the semiconductor. Which combination is right ?
I really hope that you can say which combination is original for a JTM45 out of the '60s with Angus Young AC/DC-Powerage sound ?
Regards,
Johannes
