"Black Flag" JTM schematic
- Flames1950
The HOM book also has the eight can Black Flag JTM amp schematic in there -- the single rectifier version. George's standard Heyboer made 1203-80 tranny works with the single rectifier version just fine.
- Early '67 JTM
- Alternate Schem - 1967 Hand Drawn.gif (46.72 KiB) Viewed 14445 times
- Flames1950
The above schematic is the single rectifier version, here's how to wire the dual rectifier version. All caps are 32uF, and your 1203-80 transformer replica has got to have the two individual secondary B+ windings. Courtesy of Brian Wallace, who helped me quite a bit in figuring these amps out.
- 1203-80 Wiring.jpg (33.64 KiB) Viewed 19178 times
- novosibir
Re: "Black Flag" JTM schematic
Andy, did you already notice, that in this schem the 27K FB resistor is on the wrong place?
It has to be placed 'above' the conjunction with the 10K tail resistor
Larry
Larry
- Flames1950
Ha! Never looked that closely at it I guess.....pretty much knew what I was building anyway so I didn't notice.
