45/100 Block End Now Available
- VelvetGeorge
- Site Owner
I hereby announce the release of my new flagship amplifier: the 66 45/100 block end 100 watt.
Check the listing for specs:
http://store.metroamp.com/product_info" onclick="window.open(this.href);return false;. ... cts_id=364
And have a look at the pics. Sound clips are on the way!
- (71.19 KiB) Downloaded 14156 times
- 45-100 front copy.jpg (89.54 KiB) Viewed 68576 times
- VelvetGeorge
- Site Owner
more pics...
- (70.96 KiB) Downloaded 14130 times
- (66.62 KiB) Downloaded 14140 times
- (70.65 KiB) Downloaded 14147 times
- VelvetGeorge
- Site Owner
more...
- (78.69 KiB) Downloaded 14103 times
- (75.71 KiB) Downloaded 14111 times
- (54.98 KiB) Downloaded 14126 times
- VelvetGeorge
- Site Owner
and more...
- cap board copy.jpg (75.58 KiB) Viewed 68496 times
- (86.49 KiB) Downloaded 14090 times
- VelvetGeorge
- Site Owner
more.
- (41.43 KiB) Downloaded 14052 times
- (50.38 KiB) Downloaded 14047 times
- (66.09 KiB) Downloaded 14054 times
- (73.95 KiB) Downloaded 14049 times
- (85.83 KiB) Downloaded 14062 times
- VelvetGeorge
- Site Owner
- MacGaden
- Wiki Editor
- yngwie308
George,absolutely stunning ,breathtaking,one of the most beautiful amps I have ever seen.The end blocks are identical to the ones on my '66 JTM45.Love the front and rear panels.Absolutely your finest creation to date.
This has to be my favorite amp as it does so many tones,BRILLIANT.
Congratulations you have surpassed even your own incredidibly high standard,love to hear clips.
- novosibir
Wow! I'm overwhelmed
My congrats, George! That's the way 'most true to original' replica of a Marshall I've ever seen and with that amp you've set the paradigm for all the other cloners everywhere! YOU'RE da man!
Only in case you didn't know yet: The yellow print Mullards indicate the tube as the long life, high reliability & high tolerances type. They do have a better cathode coating and a better vacuum (more gain) than the std. stuff. IIRC the yello prints are assured for a longevity of 100,000 hours, when operating in conservative designs. Meanwhile an invaluable tube!!!
C'mon! Let's open a butt of whisky now!
Larry
Larry
- mightymike
George, You just raised the bar....AGAIN!
That is an absolutely beautiful work of functional art.
- Flames1950
- Flames1950
- mightymike
You know he's got to make the Dual Diamond Black Flag Next....
Then Metro clone guitars....
- mightymike
