Sharks got a broken truss rod
YMI5150?
Post by YMI5150? » Thu Dec 20, 2012 9:31 am
Any ideas on how to salvage? I've seeing the kit on stew Mac. There's not enough meat exposed to bite into. Nut at headstock end failed at the weld. May have to pop off the fretboard. Doable by heating?
Cheers
vanhalen5150
Re: Sharks got a broken truss rod
Post by vanhalen5150 » Thu Dec 20, 2012 9:45 am
Most modern glues will not separate by heating. Sounds like quite an issue. Any pics?
This vid, you'll see he uses a cutter to cut into the neck wood a bit to expose more of the rod. Not sure of the tool costs but if you want to save it, maybe your only option.
http://www.youtube.com/watch?v=-Dm_5GDHT2A" onclick="window.open(this.href);return false;
rgorke
Post by rgorke » Wed Dec 26, 2012 1:54 pm
Oh No!!!
Post by Tone Slinger » Thu Jan 03, 2013 9:02 am
Is it a set neck ? If so, you would be better off replacing the whole neck. Expensive to say the least. You would come out better getting an Epi Explorer and do it all over again.
YMI5150?
Post by YMI5150? » Thu Jan 03, 2013 9:20 am
The good news is it is playable. The strings are high in the upper frets most likely due to incorrect tilt angle. I'm fudging it by shaving the bridge height adjustment nuts. It'll be fine for what it is.
It sounds incredible.
dazzlindino
Post by dazzlindino » Wed Jan 09, 2013 8:49 pm
I have both an Epi and an Ibanez....since they are not bolt ons , doubht it would be an easy switch....
would not recomend the epi...as far as using the neck....
the frets are not precise and will not intonate without a earvana nut......tone wise the epi is not half of what an Ibanez is.....just sayin'
Dont tell me to turn it down
garbeaj
Post by garbeaj » Wed Jan 09, 2013 10:26 pm
If you have an original Ibanez Destroyer or a guitar you really care about, take it to an experienced tech and let them do the work. If they know what they are doing they should be able to fix it for under $100 including bench fee. I leave everything to the professionals.
