dukeamps
Post by dukeamps » Thu Nov 19, 2015 7:34 am
bennyx wrote:
Oh ok if you say so, you tell so many different story's it hard to keep up with you.
Well either Glenn or you are not telling the truth, I would tend to believe the guy who was actually there doing the mod with Levi.
on old video that i have remove (BRBS 36 research and development) you was see clear....i always have a 77' jmp.....and i have discovered on second time that was a cousin amp of original 36......casuality......but fuckin great.....i have buy it 6-7 years ago from Liverpool.....
anyway ,each person believe that he want believe.....no problem....seems to me very strange that Glenn remind a particular cap or component and don't remind the real maker of 39 superkill mod that are more easy to remind......so for Frank, Glenn don't say completely the truth for make publicity to Caswell.....seems that Glenn and Caswell are very friends......but i want to believe that Glenn have confused after several years and several amps and several works and mods and people......i hope......
i don't want think that Glenn have bad intentions.....but something don't touch......
Ok my bad Benny, great that you have a 77 amp :thumbsup:
I don't think we will ever know the real story.
:toast:
pjoliver182
Post by pjoliver182 » Thu Nov 19, 2015 8:33 am
No we won't but we can know the right sound by just using our ears.
I think if you have the wrong cathodes in place you end up adding more components and changing more stock components to try and compensate...when the root cause is that the cathodes are wrong. These kinds of tones sound so 'choked' and restricted and the amp loses its feel and sensitivity.
When you get the right cathodes you find there's no need to add bright caps and treble peakers...extra attenuation resistors...or modify anything in thd stock circuit really. The mod ends up being so simple with a minimal number of additional components required. It also fits with everything from glenn frank and Tim. ..the only parts that never fit are what Frank allegedy tells benny...
coldengray
Post by coldengray » Thu Nov 19, 2015 9:25 am
Sorry to interrupt the thread, but can someone PM me with the #36 layout? The links on page 140 no longer work. Thank you.
bennyx
Post by bennyx » Thu Nov 19, 2015 9:38 am
coldengray wrote:Sorry to interrupt the thread, but can someone PM me with the #36 layout? The links on page 140 no longer work. Thank you.
Depend that version you want....in this topic you find several version of 36.....everybody say that himself version are right :D
pjoliver182
Post by pjoliver182 » Thu Nov 19, 2015 2:13 pm
Actually there's only two real versions :lol:
The benny version and the "everyone else" version :toast:
novosibir
Post by novosibir » Thu Nov 19, 2015 3:03 pm
I couldt stray in 4 different versions of the #36, which I've drawn back in 2011:
- everyone_else_version
- dukeamp_version
- ryu-mod_version_1
- ryu-mod_version_2
coldengray
Post by coldengray » Thu Nov 19, 2015 3:10 pm
How about the "everyone else version"? I'd love to start there. :shred:
novosibir
Post by novosibir » Thu Nov 19, 2015 3:16 pm
No prob:
S.I.R.#36mod.pdf
(20.06 KiB) Downloaded 295 times
coldengray
Post by coldengray » Thu Nov 19, 2015 8:28 pm
Thanks Larry! Is there a layout too for reference?
novosibir
Post by novosibir » Fri Nov 20, 2015 1:28 am
coldengray wrote:Is there a layout too for reference?
Not in my hands.
Larry
pjoliver182
Post by pjoliver182 » Fri Nov 20, 2015 3:03 am
I should have some layouts somewhere...I'll have a look when I get to work :thumbsup:
coldengray
Post by coldengray » Fri Nov 20, 2015 9:11 am
pjoliver182 wrote:I should have some layouts somewhere...I'll have a look when I get to work :thumbsup:
Thank you good sir!
pjoliver182
Post by pjoliver182 » Fri Nov 20, 2015 3:17 pm
They're all missing off my Google drive :shock:
I'll try and make some more
BRMSlash
Post by BRMSlash » Fri Nov 20, 2015 10:59 pm
So I got rid of the grid stoppers on the 3rd and 4th stages, lowered all the snubbers to 150p and lowered the B+ to 285v at the cathode follower node. It's pretty bright, so had to turn the presence off and turn down the treble to around 3.5.
http://sclk.co/s7w5ii
pjoliver182
Post by pjoliver182 » Sat Nov 21, 2015 3:50 am
Interesting tone you've developed there mate. Very spongy yet buzzy at the bottom end. You must have a highly developed mod to be fine tuning the B+ voltage. Respect.
:toast:
