bennyx wrote:https://www.youtube.com/watch?v=BkxDlhxW_ZY
same specs 2 shield trick.....470n on 820......tone stack stock.....always g12-80
I also think that 470nf has to be over 820.
Sounds nothing like AFD, sounds as if your amp is not working rightbennyx wrote:https://www.youtube.com/watch?v=BkxDlhxW_ZY
Its nothing to do with business, i have no interest in making money with amp mods,bennyx wrote:Business is a bad beast.....very bad
Amp sound perfect....and work good....
Benny, I like your clip and especially that you can sell those tunes because you can play them well and with the perfect feeling. Would you be willing to share your settings, are you using an attenuator or is this just master @ 1. I can hear your strings through. Is this just recorded on your phone?bennyx wrote:https://www.youtube.com/watch?v=BkxDlhxW_ZY
yes....phone and master at 1....no power attenuator.....for the moment i can't do a better quality record....RagnarMarGunn wrote:Benny, I like your clip and especially that you can sell those tunes because you can play them well and with the perfect feeling. Would you be willig to share your settings, are you using an attenuator or is this just master @ 1. I can hear your strings through. Is this just recorded on your phone?bennyx wrote:https://www.youtube.com/watch?v=BkxDlhxW_ZY
Nigel, I really don't see the point in this. It's obvious that the recording techniques are different, especially if Benny is using his phone to record. These 2 clips are actually the same recording but two mixes, they sound quite differently.dukeamps wrote:Its nothing to do with business, i have no interest in making money with amp mods,bennyx wrote:Business is a bad beast.....very bad
I have downloaded your new clip from YT & put it with the wttj master track, to me its wrong, your track sounds very flat & muffled, & to me it also sounds like the wrong speaker, take a listen for yourself,
Benny's new clip with wttj master track,
http://soundclick.com/share.cfm?id=13282369
I would say its about 60% there.
I don't think nothing....i'm perfectly convinced that i haven't nailed 100% the afd sound....if wasn't don't change nothing in my amp.....if work on now probably is cause i would nailed at 100%.....obviously with a right record and an high volume will be sound better.....but voicing not depend to record....if you don't ear the right voicing perhaps you have some ear problems....character of amp is right....now i search the shades.....nail the shades isn't easy.....i could make it on many years....i have understand that the game are play all on shield tricks....dukeamps wrote:My point is Benny thinks its 100% AFD tone, & my opinion is its not, & whats the point of recording with your phone anyway, if Benny is trying to prove he has the AFD tone record it right, & let us all hear that it is a 100 % perfect.
In the two clips you have used as an example you can still hear its the same tone, where in Benny's case its not.
Also it seems that you are not allowed to voice an opinion around here, as soon as you do you are cut down saying you are doing it only for business reasons, which in my case is totally wrong.
Ok Frank was used a speaker for development but Slash have used the same speaker for afd recording? We are not sure......dukeamps wrote:Good for you Benny![]()
So I asked Frank Levi which speaker he used to develop the 36 mod & he told me, he is a clip from said speaker, i only had this speaker in my 1x12 box, because i only have one with 8 ohm, i will have to get a 16 ohm one,
http://soundclick.com/share.cfm?id=13282831
same spec as other clips.
