67' 1986 board
darrell
Post by darrell » Sat May 26, 2007 7:48 pm
8)
stokesdead
Post by stokesdead » Sat May 26, 2007 7:52 pm
I don't know the theory behind it. I am totally green with amp building. Maybe someone else can explain it. I just got that off the "Metro" CD.
~CS
darrell
Post by darrell » Sat May 26, 2007 8:02 pm
8)
Post by Flames1950 » Sat May 26, 2007 11:16 pm
No, the way you're doing it is not "wrong" -- my own builds do it the same way you do.
The way George's picture shows is much more stable however -- the pot will be installed rock solid with support all around. The way you and I have used works fine but the pot does kind of "float" and move a bit when you're adjusting, and probably takes a little vibration when the amp is transported.
Post by Flames1950 » Sat May 26, 2007 11:25 pm
I'm pretty sure my bias circuit grounds between the presence and bass pots on most of my builds.
darrell
Post by darrell » Sun May 27, 2007 12:29 am
8)
Post by Flames1950 » Sun May 27, 2007 8:03 am
Yeah, I connect the bias ground turrets with a jumper and only use one ground wire for the bias circuit.
darrell
Post by darrell » Sun May 27, 2007 8:42 am
8)
Post by Flames1950 » Sun May 27, 2007 8:53 am
People have been claiming that carbon tracks in bias pots can go bad for years. How many Fenders do you see with replaced bias pots? I've yet to see one. Besides, the wiper on that bias pot is all one plate with a lug on each end -- there's nothing to go bad, it's still a solid piece between the turrets.
darrell
Post by darrell » Sun May 27, 2007 9:11 am
8)
stokesdead
Post by stokesdead » Sun May 27, 2007 9:29 am
Darrell,
Dude it is the same. You say toMAYtoe and George says toMAHtoe. The electrical connections are the same. resistor to one lug and the capacitors to ground and other lug. The picture you are posting have the same connections to the pot as Georges method. Also it really seems like you are taking this all personal.
~CS
darrell
Post by darrell » Sun May 27, 2007 9:36 am
8)
Post by Flames1950 » Sun May 27, 2007 10:29 am
Three lugs are connected to ground -- on a schematic that shows as ONE connection!!! 100-watt schematics also show 100uF caps in the filter sections......huh, all I see on the amp are dual 50's connected together.....wierd.......
Sigh.......Chris, suffice it to say that you're fine.
stokesdead
Post by stokesdead » Sun May 27, 2007 12:39 pm
Thanks for the help flames. If you don't mind check my latest pics in the 50 watt section.
~CS
