sovtek mig 100u need to add some gain
cant find a schem for the 100u and need some advice about getting some more gain out of this amp
- bluesbreaking
Re: sovtek mig 100u need to add some gain
Why not just run a boost pedal into the front?
If it really needs to be in the amp, you could add a preamp tube. This was somewhere else on this site, but I posted it here for convenience's sake.
- (351.58 KiB) Downloaded 1908 times
not really looking into adding another tube more just resistor and cap tweaks
- bluesbreaking
Is there a reason it has to be the amp? I guess I don't see why you don't just run a boost pedal into the amp?
i do run a boost but i still need a touch more gain on tap for some heavier stuff my new band is playing
- jerrydyer
what have you done so far? Put a 2700pf over the gain pot. Is it 2203 like.
vids.
yes it is just a touch les gain
If you post a picture of the board i will tell you exactly what you need to do. Probably a 1uf cap on the cathode resistor of the second gain stage will do it. But.. If you want to make it a fire breathing gain machine you can, you just need to change most of the caps and resistors on the the first two stages of gain.. How much experience do you have working on electronics? Do you know how not to shock youself? You can get these amps very high gain with a little work, without adding another tube.
Here is the scematic, higher gain than i expected... But probably kinda honky due to the. 047 coupling cap.
[url][http://www.clintronics.com/images/Sovte ... ic.jpg/url]
the 100 is more like a jcm800 the 100u is like a plexi and the 100h is hot rodded 800
On he first gain stage, i would change the 100k plate resistor to a 220k with a 470pf disc bypassing it. This will lower the plate voltage from abour 250v to about 170v. This might be all you have to do, it will lower the clipping point of the tube and sound good. If you want to go bigger change the .47 bypass cap on the first stage to a 1uf capacitor. This will make for a smoother let honky gain. But you will probably then want to change the coupling cap from .047 to .022 or even .010 to filter out some of the low lows the 1uf will add. Then... I would change the 22uf cathode bypass on the second stage to a 1uf or a .068uf cap. It will make the amp tighter and just sound better in my opinion. Also i would concider a resonance mod on this amp. Ive added them to similiar circuits and they sounded great!
Wow i didnt know they made so many versions. Let me look a little closer and ill get back to you in a bit.dxjxrose wrote:the 100 is more like a jcm800 the 100u is like a plexi and the 100h is hot rodded 800
So if yours is a 100u and is like a plexi, does it have a master volume?
If yours is a non master volume its probably the same as this one.
http://www.blueguitar.org/new/schem/sovtek/mig-50.pdf
also i am not well enough versed with tube amps to know exactly which part to change via your last post alil more guidance would be greatly appreciated
