- CoffeeTones
RG58 - appears to be solid instead of stranded core conductor, 22 AWG. .195" diameter, about 31pF per foot, high working voltage rated, insulation is not great and will melt easily if heat applied too long. I'd try to seek out some coax with Tefzel or Teflon insulation, tinned and stranded copper core 22 - 20 AWG. You assume the risk. If you choose to do the mod, do it as best and safely as possible.
- Antonio
Thanks for the heads up, Coffee!CoffeeTones wrote: ↑Sat May 06, 2023 12:04 pmRG58 - appears to be solid instead of stranded core conductor, 22 AWG. .195" diameter, about 31pF per foot, high working voltage rated, insulation is not great and will melt easily if heat applied too long. I'd try to seek out some coax with Tefzel or Teflon insulation, tinned and stranded copper core 22 - 20 AWG. You assume the risk. If you choose to do the mod, do it as best and safely as possible.
Here in Brazil there is no suitable cable for hot shield.
I'm thinking of asking a friend to bring this cable from Europe, it looks good!
https://www.tube-town.net/ttstore/coaxi ... g-187.html
What do you think of this one?
Thank you so much!
Gibson Les Paul 1959 R9 "Jessica"
SIR #34/#36 Amp Replica
- CoffeeTones
The capacitance per foot is low, so you would need to use one foot to get about 20pF for the hot shield effect IMO.
Your linked description doesn't make clear the material of the center conductor (Staku stranded wire). From random data sheets, RG187 appears to be plated steel, stranded center conductor. Tinned or silver plated, pure copper is preferred IMO.
32 - 36pF per foot is better since you really shouldn't need a one foot piece from input to V1. (6 - 8 inches would provide about 18 - 24pF).
- Antonio
Great to hear that, Coffee!CoffeeTones wrote: ↑Sun May 07, 2023 9:57 amThe capacitance per foot is low, so you would need to use one foot to get about 20pF for the hot shield effect IMO.
I'm going to look for a cable that meets those specifications you gave me.
Thank you very much!
Hi guys, it's been a while since I've been back here, lately I've only played on mesa mk III and V
I would like to ask you: has anyone recorded any new takes of #34?
I would like to play it again and it would be nice to have someone to talk to (miked sound only)
- CoffeeTones
Are you posting the spec?
it was something like 4 10ks and something else, oh yes a 47p bright lol
- CoffeeTones
This fall weather is bringing back the amp fever!
I just might fire up the soldering iron again too lol
- CoffeeTones
Man, that's the wrong angle for a gut shot.
