Pickup Advice
ChuckLogan
Post by ChuckLogan » Tue Oct 02, 2007 4:59 pm
Just heard back from Bareknuckle the Rebel Yell PUP has a DCR of 14.5K . .
Wow thats higher then I would of expected . . would imagine that would over take a classic paul sound correct ? I like a (dark vintage-with a Super Charger ) type of sound . . I would think 14.5 would create some of the metal tone fizzys ????
Post by yngwie308 » Tue Oct 02, 2007 5:14 pm
Chuck did you miss my earlier post
http://bareknucklepickups.co.uk/forum/v ... php?t=2668
Rebel Yell is not a classic PAF sound, the resistance is higher, and it is for modern Les Pauls, and great with effects ala Steve Stevens sound and tone.
Post by yngwie308 » Tue Oct 02, 2007 5:15 pm
yngwie308 wrote:The Steve Stevens Rebel Yells were designed to be used with Les Pauls (modern ones) and work well with multi- effects units as well, as Steve is wont to use. They are excellent pickups and many people use them, they have a great chrunch and cut through the mix well.
http://www.bareknucklepickups.co.uk/for ... ve+stevens
Sound pretty awesome to me... :D
paulster
Post by paulster » Tue Oct 02, 2007 5:34 pm
ChuckLogan wrote:Just heard back from Bareknuckle the Rebel Yell PUP has a DCR of 14.5K . .
Did Tim confirm whether it is wound with thinner gauge wire than a typical PAF though? I'm fairly sure I've read the RY uses 43awg wire versus the more typical 42awg in a PAF-type humbucker. That means turn for turn it'll have higher DCR without a corresponding increase in output.
It's one of the reasons why DCR isn't the key to pickup output that everyone assumes.
ChuckLogan
Post by ChuckLogan » Wed Oct 03, 2007 10:35 am
yngwie308 ..
Thanks for the links, yes I saw the fiirst one thx . . wow SS has a ton of stuff that tap into his signal path . .
Regarding the guage of wire . . used no only theDCR was given.
Cheers
