metro's with pedals
rich2k4
metro's with pedals
Post by rich2k4 » Fri Apr 04, 2008 6:32 pm
do any of you guys run your plexi's on about 2-4 so it produces a beefy clean tone, and then use pedals to get your gain and lead tones?
if so, can i get some examples of how that sounds? with clips etc
leleduke
Post by leleduke » Tue Apr 08, 2008 8:10 am
I use a H&K tube factor with a SIB echodrive for my gigs but at home I just crank it.
Les Paul Forum member Mark E. Duke <<><
http://www.myspace.com/transitbr" onclick="window.open(this.href);return false;
MarshallGeek
Post by MarshallGeek » Sat Apr 12, 2008 11:03 am
I would suggest trying a Fulldrive (on compcut mode) for a double cleanboost. The first gives you a chunky rythm sound and the next is big and loud enough for leads. For heavier gain I use an OCD and for solos boost this pedal with the fulldrive.
New School, Old School, hell I don't go to school!!
'72 JMP 1959
'73 JMP 1959
'89 1962 metro PTP
'77 JMP 2203 metro PTP
Country Boy Shane
Post by Country Boy Shane » Sat Apr 12, 2008 12:38 pm
I used to put mine on about 3 and use my Fulltone '69 to do a lot of blues stuff. You've definitely got more headroom with that pedal when you're at a setting like that.
Last edited by Country Boy Shane on Mon Apr 14, 2008 1:58 pm, edited 1 time in total.
Just Feel it MAN! -Shane Gorski "Country Boy Shane"
www.flickr.com/photos/shanegorski
gutpile
Post by gutpile » Sat Apr 12, 2008 11:46 pm
I use a Tonebone VT pedal and keep my 50w clean and the 100w for gain... works great! PLUS I get to use two amps everytime I play which I use to jusitfy to my wife why I need so many amps!!! :lol:
Metro Clips
z900
Post by z900 » Sun Apr 13, 2008 5:49 am
Nah I use the ppimv which is better for me than a attenuator and give a little boost through a bad bob analogue man pedal , you can use any clean type boost to push the front end a little.
Mars Hall
Post by Mars Hall » Tue Apr 15, 2008 11:08 pm
I use the Klon Centuar on my JTM45. My buddy jbzoso2002 installed ptp board and ot in it. It gives me that cranked tone at manageable volumes.
kyle31
Post by kyle31 » Thu Apr 17, 2008 12:55 pm
I usually leave my 50 watter on about 6 and then use the ppimv to get a managable stage volume. This can get me fairly clean through crunchy with the guitar volume. Then i'll use either an ocd or a keeley fuzz head for more gain/volume boost.
berserktool
Post by berserktool » Sat May 17, 2008 8:27 pm
I get my crunch ,med gain and lead sounds from Z Vex Box of Rock,Keeley Fuzz Head and Sweet Sound Pi Face respectively. I usually have my volume at 2 ,which is very loud for me.
Marshall 1959 HW and 1960 TV cab w/ 25 watt Greenbacks.
videocat23
Post by videocat23 » Sat May 17, 2008 8:57 pm
I use some pedals into a clean plexi
guitar, wah-wah, OCD, Tube Screamer clone (set up as a clean boost), amp
"Remember Bart, when participating in sporting events, it's not who wins or loses but how drunk you get..." Homer Simpson
HARLEYIII
Post by HARLEYIII » Sun May 18, 2008 12:25 am
I set my 100 wat 12xxx series vol I at about 4, and vol II between 2 and 3. for the dirt I run a 83 ProCo Rat with the distortion at 2:00, the filter turned off, and the volume set at10:00. For boosting leads, or playing metal-ish stuff, I kick on a self modded ibanez ts808 reissue. (the ts808 is actually run into the rat. works better for me). At the end of the chain, before my delay, I run an Aphex aural xciter w big bottom to add some lows and tighten things up a bit.
I control the amp volume with my rat. Kinda unorthodox, but it works out nice. I dont try to copy EVH, or anyone elses sound. I try to have my own.
My Marshalls aint feedin' back....They're Laughin' at your Line-6
Joe Popp
Post by Joe Popp » Mon May 19, 2008 9:15 am
gutpile wrote:I use a Tonebone VT pedal and keep my 50w clean and the 100w for gain... works great! PLUS I get to use two amps everytime I play which I use to jusitfy to my wife why I need so many amps!!! :lol:
I am going to try a set up like this! That's a amps lover's approach to a pedal - one that switches amps!
Do you like the VT pedal?
