HARLEYIII wrote:Tony is defanantly the god father
Tony is a BIG influence of mine.
Kirk Windstien from DOWN said that the rest of the guys in the band laughed at him for using Fast Fret string lube. Then when they went on tour with Heaven and Hell, they saw that Tony uses it too. "See. The GODFATHER uses it, so thats good enough". I guess they quit laughing at him.
Hail Tony
BTW, I wonder how hard it'd be to build a clone of a Laney Supergroup? Arent they similar to the older 100 watt marshalls?
VERY similar to a JTM50 except with 250pF mixer bypass cap, 100pF bright cap on the bright vol pot and split cathodes on V1 - each using 1k5/25uF
The biggest part of the tone is those Partridge transformers, luckily Mercury Mags make clones.
However, these amps are still available for around the same price as any kit (maybe even cheaper) so I don't see the point from a financial view.
I used to have a topmount 60w Supergroup head - great amp and surprisingly did the Cream thing very well.
The later 60w Supergroup with the head mounted on the bottom of the chassis like a JTM45 has more headroom and is crisper sounding. That's the one I still own. Oh, and its LOUD too - they don't break up as early as Marshalls.
