Wood Clips
- rgalpin
Wood Clips
Inspired by the recent postings about the woody marshall tone in some of the early VH live youtube clips, i am attempting to get that tone. it's a long way from where i've been so i'm guessing it will be a long process searching for the components that allow for such head room and lively power in one crunchy punch. but here's my firstr step.
http://www.soundclick.com/bands/pagemus ... dID=682367
Changed from the Merc to a '74 dagnall OT.
Replaced .1uF coupling caps of v3 with 022
Replaced 560p mixer cap with 500p
No MXR EQ boost - straight in
Still using 6CA7s
Still using 56K/250p tone stack
Nothing revolutionary here just taking it closer to a stock '69 but with low filtering.
Still using 6CA7s
- Tone Slinger
I like it ! It seems a little tighter sounding than before, like how Fair Warning is slightly tighter than W. and C, First. Now you could get another variation to this by putting the .1 PI caps back in, and swapping out your tone stack with the 33/500. I like it, though, very open still, but with a little more "togetherness". Give us some more !
Awesome tone ! with an original dagnal, i settled on psuedo '67 spec. shared/820.68, .1pi but with .0022 v1b to keep some fluid sustain. also keeping 47k 8ohm tap. This lowers the gain a bit in a good way, and keeps all the feel and should give more wood. i find split cathode is a bit more squakey. not sure what you're runnin now. split sounds like?
- rockstah
Re: Wood Clips
rgalpin wrote:Inspired by the recent postings about the woody marshall tone in some of the early VH live youtube clips, i am attempting to get that tone. it's a long way from where i've been so i'm guessing it will be a long process searching for the components that allow for such head room and lively power in one crunchy punch. but here's my firstr step.
Still using 6CA7s
your best sounding clips yet!!
My EVH sound clips.
My EVH sound clips.
- rgalpin
cool - i'm pretty excited about the sound. that is with the 56k/250p tone stack. but i'm going to try the 33k/500. i'm trying to make all my component decisions based on what will limit low lows and the high highs - and i think 56/250 is the wrong choice for that. seems like 33/500 would be more wood. ya think?
- rockstah
i haven tried the 56/250 tone stack in a while but to my ears at the time it was too dark for vh.rgalpin wrote:cool - i'm pretty excited about the sound. that is with the 56k/250p tone stack. but i'm going to try the 33k/500. i'm trying to make all my component decisions based on what will limit low lows and the high highs - and i think 56/250 is the wrong choice for that. seems like 33/500 would be more wood. ya think?
mark i tried it with my amp variaced and it didnt sound good,but with straight wall voltage and the boss ge10 i was nailing the album tone,i have to say im impressed...im really starting to think its what evhs amp has tonestack wise!!250/56k
My EVH sound clips.
My EVH sound clips.
- rockstah
well we'll have to give that another try.bmf5150 wrote:mark i tried it with my amp variaced and it didnt sound good,but with straight wall voltage and the boss ge10 i was nailing the album tone,i have to say im impressed...im really starting to think its what evhs amp has tonestack wise!!250/56k
- rgalpin
just posted an A/B of the 2 stacks - check it out.
clip titles:
33/500
56/250
clip titles:
33/500
56/250
yes,im using the .022..the first time itried it 2 days ago variaced i didnt realize but my bass was on ten,it was too much,so i lowered it and ditched the variac and its alot better.i think i now like it better than the later tone stack,,crazy huh!!!
My EVH sound clips.
My EVH sound clips.
i like the 56/250 better clip wise.rgalpin wrote:just posted an A/B of the 2 stacks - check it out.
clip titles:
33/500
56/250
i may give a 300pf a try in place of the 250..your amp seems brighter than mine.
stan
My EVH sound clips.
My EVH sound clips.
- rgalpin
i thought i would like 33/500 better but i didn't.
the difference between the two was pretty obvious in the room. the 56/250 had more of a punch and sounded more "together." the 33/500 sounds like it's a little more compressed in the mids and that compression sort of has a smeared quality to it.
all these "wood clips" are a lot less distorted than the VH clips i posted previously. it's a much more difficult amp to play through. stuff doesn't just fly out of the amp. i have to keep pushing it. challenging. the clarity of tone is worth it - but i'm thinking that the true WOOD tone has even less distortion than this - so the amp is going to demand even more out of the player - if i keep going this direction, i'll have to get a better player!!
what negative feedback resistor do you use?im at 47k.
My EVH sound clips.
My EVH sound clips.
