I've done over 25 of these Bogen CHB series conversions in many different ways---- i've got a great sounding CHB35A with a Marshall model 1987-type preamp/PI--- i kept the 7868 output tubes (matched Sylvanias)---- i rebuilt the power supply to near Marshall specs (except for the 1st filtering stage which must be set up as Bogen did it due to the voltage doubler/rectifier system Bogen used on these amps---- this is assuming you would use the orig Bogen PT)---i haven't used filter chokes on these amps to keep costs down and i like the way they sound without them (Angus Young has his Marshalls modded to remove the filter chokes--- power resistors take their place).
Here's some pics of a CHB50 i did recently with a "Plexi" type preamp--- i experimented with 1" diameter filter cap cans on this one--
http://s46.photobucket.com/albums/f112/ ... A%20heads/
This one now has a custom faceplate and a Fender type jewel lamp in the rectangular hole one the front panel---- the Power and Standby switches are on the back.
I've done another CHB50/Plexi since this one with lower filtering values (a JJ 40/20/20/20@500V can and some extra axial e-caps) and a 6av6 7-pin tube in V1 (the triode section is very similar to 1/2 of a 12ax7)---- a very nice sounding amp , it goes from clean to harmonic-heavy distortion with a turn of the guitar vol pot.
This band used one of my older CHB35A/Plexi amps to record all the guitar parts on the song "Die Alone"--- it was recorded guitar straight to amp, no effects--
http://myspace.com/laddersandsnakes----- this CHB35A has cathode biased 6L6GC output tubes (another experiment---- not really better than the 7868's) and is owned now by another local player.
These Bogens can sound very good and are great to experiment with but when i've run the CHB50's against my '76 Marshall 1987 the real Marshall still stands out--- and Bogen vs. my '81 JMP 2204 is no contest.
Leftee's Boggy amps were mostly Bogen CHA-33 based--- the CHA-33 is an older Bogen design with tube rectification and 6L6GC output tubes. Leftee has done some very cool work with these and also with some Bell PA heads, too..................gldtp99
