So, when you are running an external preamp into the return in a master amp, the master volume doesn't work?jngreene79 wrote:Yep, you can run an external preamp into the effects loop return. You can A/B them with a switcher. When using the return, the volume is a lower and (on a master vol) the Master has no effect on the return volume. I think Larry has addressed this and ways to remedy it. I'm trying to build a Dumble style clean channel into a small box and us that for cleans. Very cool loop, Larry
Would the return volume act as the poweramp master volume?
