Interesting thought on a mod.....
ACDCG400
Post by ACDCG400 » Sun Aug 05, 2007 11:05 pm
hey guys! well i have a idea. i made a 69' superbass and i like it besides some of the problems it has. but i want to be able to switch between that and the superlead and superbass sounds. what controls that, and can i switch between them?
any help? because i need to consolidate amps and if i can have essentially a superbass and superlead.
The mark of a good amp is that even when your fingers ain't cookin', your amp is. -Malcolm young
Where is the "balls" control? AH! here it is. why'd they label it volume?
77custom
Re: Interesting thought on a mod.....
Post by 77custom » Mon Aug 06, 2007 6:13 am
ACDCG400 wrote:hey guys! well i have a idea. i made a 69' superbass and i like it besides some of the problems it has. but i want to be able to switch between that and the superlead and superbass sounds. what controls that, and can i switch between them?
Marshall had made a 50 watt lead/bass the model is a 1964 or 2100 (2x12 version) I think if you can find the schematic it would be what you need.
ACDCG400
Post by ACDCG400 » Mon Aug 06, 2007 12:03 pm
thanks alot!
ACDCG400
Post by ACDCG400 » Mon Aug 06, 2007 12:25 pm
i found nothing. does anyone have one or at least know a generic layout or switch for the mod?
stoo
Post by stoo » Mon Aug 06, 2007 12:34 pm
I searched around on the schematics and "to me" it looks like the only difference is the PI to output tube coupling caps. .02 for lead and .1 for the bass!
stew
When I play on weekends, I see 20 year olds who probably play rap in their
cars, but their girlfriends dance to Mustang Sally.
J. Yogore
toner
Post by toner » Mon Aug 06, 2007 12:54 pm
I think the superbass has a shared cathode on V1. I installed a switch on my 100w for split/shared and I love it. You might want to try it.
More info:
http://forum.metroamp.com/viewtopic.php?t=12039
http://forum.metroamp.com/viewtopic.php?t=832
diagram:
http://forum.metroamp.com/download.php?id=294
Here's a model 1992 "super bass" schem:
http://www.drtube.com/schematics/marshall/1992u.gif
77custom
Post by 77custom » Mon Aug 06, 2007 12:58 pm
ACDCG400 wrote:i found nothing. does anyone have one or at least know a generic layout or switch for the mod?
I'll look in my History of Marshall book when I get home. I know Mike Doyle has some schematics in the back of it. I looked on Dr. Tube and found nothing. I can't seem to get to schematic heaven, it said the account was suspended.......anyone else having that prob??
ACDCG400
Post by ACDCG400 » Mon Aug 06, 2007 5:52 pm
me too. nothing for schematic heaven. thats pretty strange. i thought those caps were the only difference. but is there a way to switch between them.4pdt switch maybe?
ACDCG400
Post by ACDCG400 » Thu Aug 09, 2007 1:17 pm
here we go guys. a layout off of soultone. can i just put the caps on a 2p4t switch?
isn't it gorgeous?
2061X layout.JPG (116.85 KiB) Viewed 2357 times
bottom, in the other foto it was cut out.
bottom part.JPG (45.95 KiB) Viewed 2343 times
top part, same as the bottom:cut off.
(21.87 KiB) Downloaded 1517 times
toner
Post by toner » Thu Aug 09, 2007 2:41 pm
Comparing a 20w with a 100w probably won't help. :?
Switching between .022uF and .1uF output couplers isn't a huge change in tone. It's almost like turning the bass pot up/down. I'm sure there's a way to wire the two sets of caps on a switch but I don't think it will do you much good. Have you tried .022uF caps in your amp to make sure it's something you even want?
Switching between shared/split cathode will give you more variety, IMO.
ACDCG400
Post by ACDCG400 » Thu Aug 09, 2007 3:12 pm
well, i plan to do that as soon as I found the pot for it, i don't believe george carries it, i might be mistaken. i just want it to sound like a superlead at the flick a switch, or 2...
jerrydyer
Post by jerrydyer » Fri Aug 10, 2007 2:25 pm
I would focus more on a 1st stage cathode switch. A super lead and a superbass can both have .1's on the output tubes coupling caps. I do that in mine i like the .1 better so , you want a trebly sound and a superbass sound as is now right? I would do the standard 1st gain stage cathode switch. your amp now has a shared cathode config, right? split it, have one 820/330 and the 2.7/.68 boom treble and bass. you can even make that switch a 2rdt and bring in and out a bright cap for the volume control. Make it a 3rdt and bring in and out a differnet mix resistor set. I wouldnt switch around big filter caps though. Its cool that you saw the difference but if your going to do that you might as well make two amps. two much switching to make them two identicals in one amp.
vids.
ACDCG400
Post by ACDCG400 » Fri Aug 10, 2007 3:10 pm
ok then, ill do that. also, will a 56k to 33k and 500p to 250p make much of a difference?
jerrydyer
Post by jerrydyer » Thu Aug 16, 2007 3:25 pm
yep 33k is a little fuller sounding 56 k a little more treble and the bass is shifted I beleive. BUt thats another switch . How many switches is too many for ya?
vids.
ACDCG400
Post by ACDCG400 » Thu Aug 16, 2007 3:32 pm
never too many, i already the resonance mod and like 3 mini toggles for various things, 1 or 2 more won't hurt. :wink:
